Here are the specs:
Copied from SELOC
Lotus S2 Exige Official Press Release
Lotus Exige Pricing for the UK
Lotus Cars Ltd has announced the pricing for the new Lotus Exige. The 192PS 190-hp, 6-speed Exige will go on sale in March 2004 with a very competitive manufacturer's suggested retail price (MSRP) of £29,995 including VAT.
Touring Pack:
* Electric windows
* Full carpet set with a lightweight aluminium passenger footrest
* Blaupunkt Woodstock (DAB and MP3 player)
* Full Alcantara trim
* Sun visors
* Stowage net
Manufacturer's suggested retail price (MRSP) = £1,795 (inc. VAT)
Performance Pack:
* Alcantara/Carbon effect sports seats with Exige logo
* 4 point harness (dealer fit for track use only)
* Cross bar
* Acrylic capped door panels
* Carbon effect door inserts
* Twin oil coolers
Manufacturer's suggested retail price (MRSP) = £1,765 inc. VAT
Forged wheels
Manufacturer's suggested retail price (MRSP) = £1,175 inc. VAT
Air-conditioning
Manufacturer's suggested retail price (MRSP) = MSRP of £1295 inc. VAT
Colours
The Exige range comes in a number of colours:
Standard Solid Colours:
* Ardent Red
* Old English White
* Saffron Yellow
Optional Metallic Colours at £595 including VAT
* Starlight Black
* Magnetic Blue
* Nightfall Blue
* Glacier Blue
* Storm Titanium
* Arctic Silver
* Racing Green
* Aubergine Purple
* Bordeaux Red
* Chrome Orange (top colour! )
* Graphite Grey
* Krypton Green
Technical Spec
GROUP LOTUS PLC
Lotus Exige Technical Specifications March 2004
Vehicle Description Technical Specifications
Engine Mid-mounted, transverse, 1796 cm3, 2ZZ-GE engine, Metal Matrix Composite (MMC) & aluminium lightweight and compact construction, 4 cylinders in line, water cooled, naturally aspirated with double overhead camshafts exploiting a Variable Valve Timing & Lift with intelligence (VVTL-i) system, hydraulic tappets, 4 valves per cylinder, multi-point sequential fuel injection and electronic ignition.
Engine management Lotus T4 engine control unit
Max Power 141 kW ( 189 hp, 192 PS ) @ 7800 min-1
Max Torque 181 Nm ( 133 lbft, 18.5 kgm ) @ 6800 min-1
Power to weight ratio 161 kW/t ( 216 hp/t, 219 PS/t )
Specific power output 78.5 kW/ℓ ( 105 hp/ℓ, 107 PS/ℓ )
Emissions control Three-way catalytic converter. Euro IV emissions compliant with full On-Board Diagnostics (OBD).
Transmission C64 Gearbox, aluminium lightweight construction, 6-speed, close ratio, constant mesh helical gears and open differential.
Suspension Fully independent sport suspension utilising unequal length wishbones, Bilstein mono-tube gas damper, Eibach coaxial coil spring at each corner and front anti-roll bar.
Chassis Lotus designed lightweight structure of epoxy bondedaluminium alloy extrusions with integral steel seat-belt support structureand lightweight steel rear subframe.
Steering Solidly mounted mechanical rack and pinion steering box with 2.8 turns lock-to-lock.
Brakes Servo-assisted, track tuned 4-channel Antilock Braking System (ABS) with Lotus/AP-Racing twin-piston fixed aluminium alloy front brake calipers, Brembo single-piston sliding rear calipers and 282 mm diameter, 26 mm thick front and rear cast-iron ventilated & cross-drilled discs.
Gear ratios First 3.116 :1
Second 2.050 :1
Third 1.481 :1
Fourth 1.166 :1
Fifth 0.916 :1
Sixth 0.815 :1
Reverse 3.250 :1
Final drive 4.529 :1
Performance Figures
0-60 mile/h 4.9 s
0-100 km/h 5.2 s
0-100 mile/h ( ≈ 0-160 km/h ) 13.2 s
Maximum speed 237 km/h ( 147 mph)
Fuel consumption - urban 12.1 ℓ/100 km ( 23.3 mile/gal (UK) )
Fuel consumption - extraurban 6.8 ℓ/100 km ( 41.5 mile/gal (UK) )
Fuel consumption - combined 8.8 ℓ/100 km ( 32.1 mile/gal (UK) )
C02 emissions 208 g/km
Weight distribution 38% Front - 62% Rear
Fuel tank capacity 40 ℓ ( 8.8 gal (UK) )
Luggage capacity 112 ℓ - 50 kg
Dimensions
Wheelbase 2300 mm
Track - front 1457 mm
Track - rear 1507 mm
Overall length 3797 mm
Overall width (door mirrors excluded) 1727 mm
Overall width (door mirrors included) 1850 mm
Overall height - midladen (as per unladen with 2x 75 kg occupants) 1159 mm
Overhang - front 805 mm
Overhang - rear 692 mm
Ground cleareance - midladen (as per unladen with 2x 75 kg occupants) 130 mm
Vehicle mass - unladen (running order, full tank of fuel, no occupants, no luggage) 875 kg (no options) - 916 kg (full options)
