1 - 19 of 19 Posts
New to this form and also to the Lotus experience.
Just purchased Lotus993r’s ardent red Exige. Should be with me in the coming days. Super cool guy and a mega clean car.
Also own an M4 - so looking forward to seeing how this handles in comparison.
Any advice on things to keep an eye out for, tips / tricks etc welcomed.
Very nice!
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
6. As per some engine builders on these sites, wait AT LEAST 20 minutes after coolant has reached full operating temp before engaging cam switchover.
http://www.lotustalk.com/forums/f311/cooling-ticking-timebomb-how-your-cooling-u-tube-47232/
http://www.lotustalk.com/forums/f320/remote-key-fob-immobilizer-misc-alarm-programming-70940/
14. Visit the Uber Thread
http://www.lotustalk.com/forums/f3/elise-exige-uberpost-read-everything-you-need-know-here-25131/
15. Most parts on the car are made by Toyota and others, so buying things like a/c compressors, engine parts, etc. is wildly expensive when purchased thru Lotus.
16. The soft high-grip tires on most of our cars lose much of that grip when temperatures drop below 50 F. I know of too many ppl who spun their cars when not remembering this. I use hi-performance all-seasons.
Plus, “How to bleed brakes”:
http://www.lotustalk.com/forums/f101/how-bleed-brakes-241138/
How to Search:
Transmission Fluid change what bolt site:lotustalk.com no space betw site:lotustalk.com
Welcome and congrats! Was following his for sale thread and you definitely bought a very clean Exige. Glb covered pretty much everything in the previous post. Enjoy and drive safe!
Reactions: Scoop101
The M4 (or nearly any car) will cease to bring you the pleasure it used to the first time you drive it AFTER you drive the Exige. It's happened to all of us.
San
^^This.^^
Close analogy:
Exige = go kart
M4 = riding lawn mower
You'll see.
I always laugh at these types of comments :grin2:
Congrats on your purchase! You will be forever hooked.
I sold my Elise a while back... and told myself I would get something more... m4 like.
1.5 months later I was in an Exige S240.
Seems we are getting quite a few new Los Angeles members. Maybe time to get the LA Dinner meets going again.
Reactions: Crazy05
Was Lotus993r in Socal? I remember seeing a super super clean red 06 exige at one of the lotus cruises I went on (not too many red 06 Exiges, you know?).
** The Enforcer **
Discussion Starter · #12 ·
Discussion Starter · #13 ·
I always laugh at these types of comments /forums/images/LotusTalk_2015/smilies/tango_face_grin.png
Guess I’ll Be keeping both then ?
I’m also a Red Lotus Exige owner in LA (Venice). I do a drive up PCH a few times a month. Early mornings On weekends. So much easier without the traffic. Dinners can be tough mid week (for me at least). But if anyone is interested in ever meeting up at luxxe coffee in Malibu in the mornings pm me. Love talking lotus.
Discussion Starter · #17 ·
Will have to arrange something when mine arrives. Yours looks exactly the same as mine. Looks great in Ardent red.
Discussion Starter · #19 ·
1 - 19 of 19 Posts
