1 - 6 of 6 Posts
Administrator
Welcome to LT and congrats on your Exige!
much fun in store for you.
Welcome & congrats.
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need...
Plus, “How to bleed brakes”:
How to Bleed Brakes
How to Search:
Welcome & congrats.
5. Transmission:
And, use:
How to Bleed Brakes
How to Search:
Thanks!!
Congrats! There are several informal Lotus "clubs" in the area. Tri-State Lotus Owners
If you're on Instagram, send @nathanzender a DM and ask him to add you to the Columbus Lotus chat.
Edit: Nevermind, I think I just figured out you're already on there...
1 - 6 of 6 Posts
