1 - 20 of 32 Posts
Hi everyone,
Brand new to owning a Lotus. Just purchased a 300hp turbo widebody Elise. Coming from a 1000hp LS swapped Nissan 300zx. It is definitely a totally different car. Slower in a straight line, however alot of fun. The weight difference is ridiculous and very excited to start really taking some turns. 馃榿
Hi everyone,
Welcome. I've had my 2006 Exige for 12 years. Nothing but fun.
Administrator
Welcome to LT!
2005 Lotus Elise
Very cool! Can we see some more photos of that wing!
1. These cars have large (i.e. dangerous) blind spots. Multivex mirrors are NLA, but RLS (Really Light Stuff) offers very good tape-on replacements/. GRP (Greg鈥檚 Racing Parrs) offers Extend -a-View mirrors, but I鈥檝e not seen them.
2. The horns are way too weak (quiet). There鈥檚 an inverse relationship: smaller the car, louder the horn needs to be.
Sounds like this 鈥渆xcuse me鈥濃.
Get something such as a Stebel Nautilus. Or, from beloved parts supplier, RD Enterprises: Compact Air Horn $59
Ultra Compact two-tone air horn unit measures about 4-3/8" tall x 5" long x 3" wide and weighs under 2 lbs., and it's LOUD! The sound measured at 2 meters is 115 dB. Easy installation because there's only one part to install, horn compressor relay and instructions included.
Stebel: 鈥淗ONK! LOOK OUT!鈥
Stop way behind trucks, SUVs, etc. Some have blindspots >50鈥. )
5. Transmission:
The best transmission lube I鈥檝e found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
a) Early cars have wobbly shift towers. Look up Stan鈥檚 Mod (bolt and spacer; http://www.billswebspace.com/ShifterReinforcement.pdf) and
And, use:
These (lube, mods) make a huge change in shifting. I also reoriented one swivel joint.
6. As per some engine builders on these sites, wait AT LEAST 20 -35 minutes after coolant has reached full operating temp before engaging cam switchover.
For street cars, consider removing one or both oil coolers. Some cover them. Oil doesn鈥檛 get hot enough on street, leading to cam wiping.
7. Rear toe-links can loosen and break with disastrous results. You can check tq periodically, or use Nordlock washers. Best is conversion to better engineered brace, such as BOE鈥檚 and InoKinetic鈥檚 for two examples.
8. While under the car with panel off, look around for hoses and wires chafing their way to failure. That鈥檚 how this was found:
11. Life will be better if you disable the auto-arming alarm function on the earlier cars. You won鈥檛 have to press a button to start the car. Instructions:
13, Some on this site are a bit obsessed with hockey pucks for lifting the car. Don鈥檛 use these. Too hard and slippery, generally, and too small a surface area. Use a piece of wood, as your hero does.
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need...
18. Many benefits to joining Lotus Ltd (USA Lotus club). Get help wherever you are, using the contact booklet they update every year. (I鈥檝e helped a few ppl who contacted me.) This is who stages LOGs (Lotus Owner Gatherings) every year. https://lotusltd.com
Plus, 鈥淗ow to bleed brakes鈥:
Maintenance and Repairs.
How to Search:
no space between site: lotustalk.com
2005 Lotus Elise
Good luck getting heat in those tires!
1 - 20 of 32 Posts
