1 - 9 of 9 Posts
Hello everyone, i've been reading and scrolling through this forum for a few months now, don't really like posting much, but here is my Lotus that Trackspec helped me build less than a month ago. It was a bone stock 2011 Lotus elise R. Jon, the owner at Trackspec Autosport is a long time friend of mine since childhood. He helped put Jrz coilovers, baffled oil pan, full tune up and dialed the car in ready for track. Hope to see you guys around!
1266891
1266892
1266894
LOVE IT!!!
Ask Jon and Victoria about GGLC Track Days (Golden Gate Lotus Club). Next up is Aug 10 at Laguna, but unfortunately it's sold out and the waitlist is pretty long.
Cheers,
Kiyoshi
2010 Lotus Exige S260 Sport
Welcome.
I think I have seen your car when I was checking for updates in my car at Jon’s shop. You gonna enjoy it! Sadly mine is still in the shop waiting for the last piece of adjustment in tune.
LOVE IT!!!
Cheers,
Kiyoshi
its sold out or else I would’ve joined on that one
Nice car & color.
Good for you!
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need...
Plus, “How to bleed brakes”:
How to Bleed Brakes
How to Search:
Nice car & color.
Good for you!
5. Transmission:
And, use:
How to Bleed Brakes
How to Search:
Thanks so much, good to know. I think I got everything covered.
1 - 9 of 9 Posts
