1 - 10 of 10 Posts
Got my 2006 British Racing Green last month - it's been a Colorado car its entire life and I haven't seen another super-bare base model like this....0 options, no packages, cloth seats, crank windows... But previous owner left a bunch of bolt-ons on this car...
Your Elise is awesome man. Love how bare bones it is. Also, British Racing Green is one of the best colors, good find! Have fun with her!
New member just starting on my Lotus journey, don't currently own a lotus but really want to in the future. If anyone is curious I'm driving a 2012 Suzuki Swift Sport and think an exige would compliment that well as a weekend toy or daily (because I'll probably like it and try it). I'm in the UK, 23 and a trainee teacher. I hope to gain an understanding of lotus ownership and make a few friends along the way.
2006 Lotus Elise BRG
Another 06 BRG here, although in NY. Power windows ?, but I love it all the same. I talked to a guy at the Watkins Glen Festival that had a Lotus Racing Green Elise and didn't know they made a BRG. He asked if I had it resprayed in BRG.
Good for you!
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
6. As per some engine builders on these sites, wait AT LEAST 20 -35 minutes after coolant has reached full operating temp before engaging cam switchover.
I use Mobil 1 5W-40 Turbo Diesel oil. 85k miles and fine, but one is a tiny example.
http://www.lotustalk.com/forums/f311/cooling-ticking-timebomb-how-your-cooling-u-tube-47232/
http://www.lotustalk.com/forums/f320/remote-key-fob-immobilizer-misc-alarm-programming-70940/
14. Visit the Uber Thread
http://www.lotustalk.com/forums/f3/elise-exige-uberpost-read-everything-you-need-know-here-25131/
15. Most parts on the car are made by Toyota and others, so buying things like a/c compressors, engine parts, etc. is wildly expensive when purchased thru Lotus.
16. The soft high-grip tires on most of our cars lose much of that grip when temperatures drop below 50 F. I know of too many ppl who spun their cars when not remembering this. I use hi-performance all-seasons.
Plus, “How to bleed brakes”:
http://www.lotustalk.com/forums/f101/how-bleed-brakes-241138/
How to Search:
Transmission Fluid change what bolt site:lotustalk.com no space betw site:lotustalk.com
Welcome!
I'm another BRG '06 with crank windows.
Have you considered joining Lotus Colorado? https://www.lotuscolorado.com/
We have a meeting coming up at Ferrari of Denver (i.e. Lotus of Denver) on Sunday 10/13. We do a couple 3 or 4 day drives each year, a number of 1 day drives, a few track days, and some other social events.
Yeah, already joined! I see your car in just about every local photo album ?
1 - 10 of 10 Posts
