1 - 3 of 3 Posts
Hello,
I now own a 2006 Elise! I'm excited about getting her sorted out. She needs tires, a new headliner, fluids, etc. Overall good shape. Some road rash on the front chin. I'm sure I'll have lots of questions.
Anyone autocross or any clubs in the Santa Barbara area?
Thanks!
Good for you!
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
6. As per some engine builders on these sites, wait AT LEAST 20 -35 minutes after coolant has reached full operating temp before engaging cam switchover.
http://www.lotustalk.com/forums/f311/cooling-ticking-timebomb-how-your-cooling-u-tube-47232/
http://www.lotustalk.com/forums/f320/remote-key-fob-immobilizer-misc-alarm-programming-70940/
15. Visit the Uber Thread
http://www.lotustalk.com/forums/f3/elise-exige-uberpost-read-everything-you-need-know-here-25131/
Plus, “How to bleed brakes”:
http://www.lotustalk.com/forums/f101/how-bleed-brakes-241138/
How to Search:
Transmission Fluid change what bolt site:lotustalk.com no space betw site:lotustalk.com
Welcome to the Lotus insanity!
There's a great group of Lotus enthusiast out that do drives, meet-ups and an occasional track day. Check out lcosc.org. I believe they have a drive planned in a couple of weeks.
I think the closest autocrossing group is the PCA region in Santa Maria. They do events at the Santa Maria airport. https://ccc.pca.org/autocross-and-de-events/
The GGLC hosted the West Coast Lotus Meet in Solvang in 2017 and we used the Emergency Vehicle Operations Course (EVOC) at the Allan Hancock College in Lompoc (check the aerial view on Google maps) for the WCLM autocross.
Cheers & Happy Lotusing!
Kiyoshi
1 - 3 of 3 Posts
