1 - 7 of 7 Posts
Just picked up a 2005 Elise, BOE 300 supercharged, base model Ardent Red. It is a lovely, if hair-raising experience thus far. I am excited to learn more and drive more. The Elise joins my small stable: 89 325i, 03 911 C4S, 95 911 C2, 94 Land Cruiser. I’ve got perhaps one too many now :)
1256667
1256669
1256671
Wingless Wonder
WELCOME!
"Perhaps one too many" Porsches? J/K
What's that behind the Elise, a Jaguar XJ? It's not nice to tease us with blurry pictures, you know. :rolleyes: :giggle:
Good for you. These are wonderful cars.
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
http://www.lotustalk.com/forums/f320/remote-key-fob-immobilizer-misc-alarm-programming-70940/
15. Visit the Uber Thread
http://www.lotustalk.com/forums/f3/elise-exige-uberpost-read-everything-you-need-know-here-25131/
Plus, “How to bleed brakes”:
http://www.lotustalk.com/forums/f101/how-bleed-brakes-241138/
How to Search:
Transmission Fluid change what bolt site:lotustalk.com no space betw site:lotustalk.com
Thanks for the guide. I’d already prepped what I could before even getting the car :). Now just need a few backup keys cut.
@carbuff the black car is my E30 sedan. Some less blurry photos :)
1256710
1256711
1256713
1 - 7 of 7 Posts
