1 - 5 of 5 Posts
I am a huge car nut have have been looking for an Elise to fill the void that comes from not being able to afford a Mclaren F1 for some time. I recently jumped on one in Arizona with a bit over 95K miles on it and it is honestly every bit of what I expected (apart from the crappy 2005 seats).
Day one was the first time in more than 5 years since I have actually seen a Elise in person smaller than I remembered, I purchased the can and then drove 350 miles home.
Day two was followed by a 200 mile weekend drive going up the mountain and driving some back roads. I then decided to start tearing down the car to address some electrical issues and pull out all of the aftermarket stereo from a previous owner (I plan on documenting the build and the electrical work)
I am glad to finally be apart of the family and plan on putting this car well past 300,000 miles.
1258382
Wingless Wonder
1988 Esprit Turbo
WELCOME!
To truly become part of the family, join the national Club, Lotus,Ltd and plan now to make the short drive ? to Salt Lake City for the national Lotus convention!
WELCOME!
It sounds like it would be quite the experience and I will definitely look into it, it seems like I will have plenty of time to plan.
Yes, welcome.
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need to know is in here**
Plus, “How to bleed brakes”:
How to Bleed Brakes
How to Search:
1 - 5 of 5 Posts
