1 - 10 of 10 Posts
Thanks! Here's a very quick shot next to a miata. Hard to see in the picture, but the interior is red.
Thank you for the LCOSC.org recommendation! I'll have to look them up.
1265561
Super Moderator
Congratulations I'm sure you're ready to let the good times roll!
Nice car!
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need...
Plus, “How to bleed brakes”:
How to Bleed Brakes
How to Search:
Thank you all!
I take it there is no easily accessible oil temperature reading to help make sure I block/disconnect the right amount of oil coolers? I have some experience with cars with oil coolers and getting oil temperature readings was great in helping to stay on top of oil temps (too low or high).
1972 Lotus Elan Sprint
Congratulations and Welcome!
There are several different approaches for getting oil temp, displaying it, and helping it get up to/stay at temp. Do searches.
Does your 2005 have the twin oil coolers (behind front side grilles)? Has it had the oil cooler line recall?
Discussion Starter #10
Thanks NCsteve!
Yes to both. Got two oil coolers and the recall has been done. I've started doing some research and see folks adding analog gauges as well as sleek color coded LEDs. Now I have to decide which way I want to go and what I want to do with the oil coolers (block or disconnect).
Got to change the air filter today. Now I understand why there are so many threads on this. Happy it's finally done.
1 - 10 of 10 Posts
