1 - 9 of 9 Posts
Hello there! I just purchased a 2005 Elise and I am flying to LA tomorrow morning to pick it up. This will be the 3rd Lotus I currently own.
I recently retired after 35 years in IT and the Elise is my retirement gift to myself! You're damn right I deserve it!!! :grin2:
Brian
1971 Lotus Europa S2
1971 Lotus Europa S2 (parts car)
1994 Caterham HPC
2005 Lotus Elise (Soon!)
Discussion Starter #2
I am flying to LA tomorrow morning to pick up a 2005 Elise I just purchased. This will be the 3rd Lotus I currently own.
I recently retired after 35 years in IT and this is my retirement gift to myself! You're damn right I deserve it!!! :grin2:
Brian
1994 Caterham HPC
2005 Lotus Elise (soon!)
Awesome retirement present. Well deserved. Congrats, enjoy, and be safe! Be sure to post some pics when you get it.
Gabe
Good for you.
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
3. The early cars came with misaimed and dim headlights. If you drive at night, convert to HIDs. While better than stock halogen bulbs are available, HIDs throw more light. Stay around 5000k.
5. The best transmission lube I’ve found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
And, use:
6. As per some engine builders on these sites, wait AT LEAST 20 minutes after coolant has reached full operating temp before engaging cam switchover.
For street cars, consider removing one or both oil coolers. Some cover them.
http://www.lotustalk.com/forums/f311/cooling-ticking-timebomb-how-your-cooling-u-tube-47232/
http://www.lotustalk.com/forums/f320/remote-key-fob-immobilizer-misc-alarm-programming-70940/
14. Visit the Uber Thread
http://www.lotustalk.com/forums/f3/elise-exige-uberpost-read-everything-you-need-know-here-25131/
15. Most parts on the car are made by Toyota and others, so buying things like a/c compressors, engine parts, etc. is wildly expensive when purchased thru Lotus.
16. The soft high-grip tires on most of our cars lose much of that grip when temperatures drop below 50 F. I know of too many ppl who spun their cars when not remembering this. I use hi-performance all-seasons.
Plus, “How to bleed brakes”:
http://www.lotustalk.com/forums/f101/how-bleed-brakes-241138/
How to Search:
Transmission Fluid change what bolt site:lotustalk.com no space betw site:lotustalk.com
Supporting Vendor
Congrats. The Elise is a modern icon.
We are restoring a '73 Europa TC Special. See details: HERE Looks like you have some experience with Europa. Call me if you have any questions about the Elise and I can pick your brain for Europa tid bits.
Congratulations! We've got a great group of Lotus owners in Utah. Look up the "Lotus Cars Utah" group on Facebook or PM me. Can't wait to see you out on the roads.
I apologize it took me so long to get back to reply to all the welcome messages I received. Thank you for the warm welcome!
Shinoo, I will be happy to help in any way that I can. My two Europas are both the S2 models so they have the Renault motor and those are the ones I am most familiar with. If you are interested I would recommend joining the Lotus Europa list on Yahoo Groups. There are a number of people there who know the cars inside out and everyone is very friendly!
glb, thank you for the informative post!
Turbopun, WAY better than a gold watch! I think all I got was a boot out the door!
Themadknight, have you made your way to the ULOCO (Utah Lotus Owner's Coalition) meetings yet? I am the Treasurer for ULOCO. If you have made your way we are certainly acquainted! The next ULOCO meeting will be at British Field Days in Liberty Park on June 15. Unfortunately I have not made the required 5 posts yet or I would PM you. I expect I will be at the 5 limit shortly!
Here are some pics:
1 - 9 of 9 Posts
