1 - 11 of 11 Posts
Very nice!
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
6. As per some engine builders on these sites, wait AT LEAST 20 minutes after coolant has reached full operating temp before engaging cam switchover.
http://www.lotustalk.com/forums/f311/cooling-ticking-timebomb-how-your-cooling-u-tube-47232/
http://www.lotustalk.com/forums/f320/remote-key-fob-immobilizer-misc-alarm-programming-70940/
14. Visit the Uber Thread
http://www.lotustalk.com/forums/f3/elise-exige-uberpost-read-everything-you-need-know-here-25131/
15. Most parts on the car are made by Toyota and others, so buying things like a/c compressors, engine parts, etc. is wildly expensive when purchased thru Lotus.
16. The soft high-grip tires on most of our cars lose much of that grip when temperatures drop below 50 F. I know of too many ppl who spun their cars when not remembering this. I use hi-performance all-seasons.
Plus, “How to bleed brakes”:
http://www.lotustalk.com/forums/f101/how-bleed-brakes-241138/
How to Search:
Transmission Fluid change what bolt site:lotustalk.com no space betw site:lotustalk.com
Very nice!
https://www.lotustalk.com/forums/f101/how-bleed-brakes-241138/
How to Search:
Thats some good info man, Thank you.
Ive noticed the blind spots but Ive owned a couple C3 vettes so they are about the same.
One of my first purchases will be new headlights. When I picked up the car and drove it the 2hrs home, on the last 10 min I found how bad they really are.
While Im thinking on it I do have one question. I dont have the pin for the car. How would I go about getting this?
Call the HOUSTON lotus dealer and ask for service and they will tell you. Or any other one, just don't bother with Austin. You will need the vin.
Congrats on the purchase! As far as headlights go, replacement stock bulbs won't help too much IMO. You can look into getting HIDs or the alternative(cheaper) is LED bulbs. With the LEDs, they will be much brighter but beware they won't shine as far. I have them and I'm totally fine as I don't often drive the Elise at night. I just need to be able to see what's in front of me which does the job. Enjoy!
Gabe
1 - 11 of 11 Posts
