1 - 5 of 5 Posts
I recently got my hands on a 2005 Elise, my first Lotus experience. She's mostly all stock with the exception of a performance exhaust and a few trim pieces the previous owner put on. The last owner put on this set of aftermarket wheels but I got the original set as well. I'm hoping to learn more about these cars as I plan to do small maintenance myself. I'd like to track my car at some point but for now just a bit of weekend fun.
1268376
Administrator
Welcome to LT! Great place to learn about Lotus especially if you plan on maintaining it yourself.
Congratulations! Nice looking ride!!!
2005 Lotus Elise - Touring
Great looking Elise! I just picked up an Ardent Red 2005 a month ago and have loved every day of it!
Nice car.
You're in for lots of fun.
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need...
Plus, “How to bleed brakes”:
How to Bleed Brakes
How to Search:
1 - 5 of 5 Posts
