1 - 4 of 4 Posts
Hello I am TomD. I have a 2007 Dark grey metalic elise. It is a salvage title due to a front clamshell altercation 2 weeks from new according to the carfax. Getting to know the car and looking forward to fun with it.
Welcome! Probably Storm Titanium or Graphite Grey in color...? Post some pics to show her off! There's a lot of info here at LT. How long have you had her?
You will love this car.
Best I've ever owned.
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need...
Plus, “How to bleed brakes”:
How to Bleed Brakes
How to Search:
1 - 4 of 4 Posts
