1 - 4 of 4 Posts
Lotus Elise 2006 Canyon Red
I am a new member and have a 2006 Canyon Red Lotus Elise, which I am in love with. My sweet hubby purchased the car for my birthday in May and it is an awesome addition to our family. We live in north Georgia and have taken 'her' on the curvy North Georgia mountain roads and she performed flawlessly.
shay2nak
Wow, congrats! Welcome!
That''s a terrific color.
These are amazing cars.
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need...
Plus, “How to bleed brakes”:
How to Bleed Brakes
How to Search:
1 - 4 of 4 Posts
