1 - 9 of 9 Posts
Hi everyone I'm currently a Porsche guy with a 86 911 and a 2012 Cayman. However, the Lotus bug has bit me and there are a few Elises in my area that are on my list. One has been modded with a Magnuson MP62 supercharger and intercooler. The HP claim is 300+. I hope that claim is inflated as that would seem to me to be pushing the stock NA engine more than I would like. Does anyone have experience with such a setup? Apparently the dealer has had ECU problems, it is not the S flash but a custom one and somehow it "went away" (according to the sales guy). With some effort, the dealer found the supplier and had it reflashed so the car is running. Does this story make sense to you? I thought a flash into memory was a permanent thing. Anyway, I am quite handy and capable of trouble shooting and analyzing systems so these issues have not made me run - yet. One thing for sure, I would want to detune the system to be more in line with say 230 HP. IMHO, that is plenty for such a light car. I haven't seen the car in person, all this info is from the sales guy and pictures. On Monday, I'm going to have a really good look at it and will take pictures of the SC setup etc. I have viewed the Lotus buying videos, many thanks to Rob Dietsch for putting all the effort into them.Any thoughts and/or suggestions welcomed. Thanks!
I am not a fellow that knows supercharger brands, but I can tell you:
I have ~300 hp at crank, i.e. 254 a wheels. You don't say where that 300 hp supposedly is, but the distinction is important.
And....
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
6. As per some engine builders on these sites, wait AT LEAST 20 -35 minutes after coolant has reached full operating temp before engaging cam switchover.
http://www.lotustalk.com/forums/f320/remote-key-fob-immobilizer-misc-alarm-programming-70940/
15. Visit the Uber Thread
http://www.lotustalk.com/forums/f3/elise-exige-uberpost-read-everything-you-need-know-here-25131/
Plus, “How to bleed brakes”:
http://www.lotustalk.com/forums/f101/how-bleed-brakes-241138/
How to Search:
Transmission Fluid change what bolt site:lotustalk.com no space betw site:lotustalk.com
Oops. Forgot to mention that BOE (a company I really trust) makes a 400 hp version too. The 300 version is very reliable. Don't worry. There are other S/charger vendors, but I voted with my checkbook (OK, credit card.)
** The Enforcer **
I went with a flash (Blade 300) and supporting mods a few months after purchasing my 2007 Exige S. Stock SC (MP62) with a better intercooler, injectors, flash and smaller pulley. 281rwhp, so about 325 crank. It's been very reliable and I've had no issues in the almost 9 years I've owned the car. I'd like to increase the horsepower, but I'd need a built block, REV400 or REVX and likely a built transmission. That would be nearly $30K, so I'm sticking with what I have. I have a few other toys that can satisfy my desire for stupid acceleration when needed.
San
Thanks for the wealth of info glb and oldmansan. Lots to digest there and I am encouraged by your statements about the 300 or so HP number not being an issue (as far as longevity) . I'm really looking forward to learning the brand and of course, driving it.
** The Enforcer **
Dyno plot showing A/F ratios and HP/TQ.
San
Discussion Starter · #7 ·
Torque curve, what torque curve? It's almost a wonderful straight line. And HP just builds in a linear fashion. OK, I'm in with those numbers.
** The Enforcer **
I didn't say curve. It's not bad for the stock SC.
San
Discussion Starter · #9 ·
No San, that was me making comment and admiring the dyno graph. Thanks for sharing it. But based on the just shy of 300 HP, I thought it was your car, not a stock one. Is that how the Dynojet expresses it?
1 - 9 of 9 Posts
