1 - 9 of 9 Posts
Hi All,
Just purchased a 2005 Elise in Storm Titanium from another member here in central Ohio. Car has a K20 swap as well as a number of other modifications. First time Lotus owner but I have had a pretty eclectic history of vehicles (260Z, Imprezza, WRX, Healey Sprite, BMW 230i, Genesis G70). For the rest of this year I plan to just learn and drive the car, with maybe a few small project this winter. This forum certainly helped me be confident in my purchase decision and I'm sure will continue to be an excellent resource going forward.
Andrew
Administrator
Welcome to LT Andrew! You've certainly added another eclectic vehicle to your garage.
Drives beautifully. All the hard work is done. I've never driven a stock Elise so I can't give you a direct comparison, but the K20 intake noise and free reving nature matches the character of the vehicle.
1268042
1268043
1268044
Very nice indeed.
Car looks terrific. Congrats.
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need...
Plus, “How to bleed brakes”:
How to Bleed Brakes
How to Search:
1 - 9 of 9 Posts
