1 - 5 of 5 Posts
Hey everyone,
I recently acquired this 2006 Elise. To be honest, I never in a million years would have purchased this but it kind of fell into my lap at a super low price. I don’t know a single thing about the cars so I’m looking for some help on exactly what I’ve got here.
I know it’s 2006 Elise Roadster? Seats are cloth. Anyone know about the aero kit that’s on it? Doesn’t seem to be something I’ve seen on a lot of Elises. What else should I look for that will differentiate packages?
That’s really all I’ve got right now. Working on tracking down more paperwork but nothing other than a title right now.
2006 Lotus Elise BRG
Cloth means you also have crank windows and no Touring package (some people prefer this). You have Sport Package wheels but that doesn't guarantee Sport Package.
Don't know about the aero kit, I'm sure someone does.
Also interesting your 06 has the lower reflectors from an 05.
Administrator
Do you have further away and lower photo of front splitter. Where it meets the wheel sort of looks like NCI full race.
I think I saw that for sale briefly.. rare color and if you wanted to autocross in SCCA AStreet may be a great starting point as it's the lightest combo! Pics of interior and door jamb front tire size will tell if is sport pak. If stock shocks & springs, post pics to confirm that.
Looked for a while for my Chrome orange and saw that color you have and at first didn't like it, but it's growing on e.. Congrats on a Krypton Green gem!
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need to know is in here**
Plus, “How to bleed brakes”:
How to Bleed Brakes
How to Search:
1 - 5 of 5 Posts
