1 - 8 of 8 Posts
Hey all,
New member here and the proud new owner of my first ever Lotus, a 2006 Lotus Sport Elise #28/50. Just picked her up in Vegas yesterday and had a blast on the drive back to SD. Been in the market for an Elise for a while and finally pulled the trigger on one I found in the classifieds section. Looking forward to learning from everyone on here!
Pics are from the previous owner since I haven't had time to take some good ones yet.
Welcome from another SD member! That's a beautiful car that I looked at, but I am trying to get back into Autocrossing and the Sport model Elise is exempt from the Street class in SCCA :cry: Maybe I'll see you at an Autocross someday anyway!!
1263047
CONGRATS on your new Baby!!
PS- Funny, I know an Andrew Ellis from the AutoX.. I suspect not the same?
Nice! Welcome--from one Newbie to another.
I just picked up my Lotus a couple days ago. I'm jealous you got to drive from Vegas to San Diego. I only got to drive my car 6 miles from the seller, then I was already home.
Thanks and nope different person, Ellis is my middle name
Great looking car.
Good for you!
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need to know is in here**
Plus, “How to bleed brakes”:
How to Bleed Brakes
How to Search:
1972 Lotus Elan Sprint
Congratulations Andrew!
I'm also a new Elise owner in North County SD, got an Ardent Red 05 through Shinoo.
I had been interested in yours and enjoyed discussing it with the seller, Patrick, a very good guy.
Happy to send some info on the 06 Sport Elises if you're not already totally up on them.
You may be interested in joining the SD Lotus Club - it's a chapter of the Bay area's Golden Gate Lotus Club.
San Diego Lotus Club
Looking forward to getting together!
Steve
It's good to see more San Diego Lotus owners. We have a fairly active group in San Diego for morning drives and the occasional social. Once this mess clears we'll look forward to setting up an organized drive.
1 - 8 of 8 Posts
