1 - 9 of 9 Posts
Well, after 15 years and 5 Miatas, my desire for something a little more focused pushed me into a Lotus Elise! In November, I bought a 2005 Magnetic Blue over tan leather with sport and touring packages on BaT.
This forum has already been an amazing resource for me, from evaluating the purchase decision in the first place to figuring out how to unlock the car when it got delivered. Thanks!
I’m about to rent a lift at a garage here in San Antonio and change all the fluids and filters, and again, this forum is a great resource!
Looking forward to consuming all the great info here and adding value myself as I figure this thing out.
1259084
Good for you!
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need to know is in here**
Plus, “How to bleed brakes”:
How to Bleed Brakes
How to Search:
Congrats! and Welcome
Congrats and welcome! I live in Houston and also just got my 07 Exige S delivered a couple days ago. I had an Elise previously and you will love it! The biscuit interior is my favorite.
Welcome to the family. I was just down your way to see the Lone Star LeMans at COTA over the weekend and stopped over San Antonio for an overnight-er and some sight-seeing. San Antonio is a very pleasant city, wish I had more time to take it all in.
1 - 9 of 9 Posts
