1 - 5 of 5 Posts
Socal
On Father’s Day bought a 2005 orange elise
with 8500 miles
Have been looking for a while for a stock low mileage orange
and found it just 150 miles from my house!
l have already put 1000 miles on it around so cal.
paul
Administrator
Congrats on the new car! What a find and being close made it even sweeter!
1972 Lotus Elan Sprint
Welcome Paul!
You may want to join one of the SoCal Lotus clubs for meet-ups and drives (though fewer than usual right now).
Good for you. Welcome.
There is lots of fun in the future for you.
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
These (lube, mods) make a huge change in shifting. I also reoriented one swivel joint.
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need...
Plus, “How to bleed brakes”:
How to Bleed Brakes
How to Search:
with 8500 miles
paul
Pics or it didn't happen! :)
Kevin
1 - 5 of 5 Posts
