1 - 14 of 14 Posts
Hey yall. I just purchased an 05 Elise with 35k miles. I live about 20 minutes south of Madison WI. Just checking in to get a pulse on the Lotus scene around me. I am hoping to meet some other owners and attend some meet-ups. Anyone close to the Madison area?
Kind regards,
KMB
Kind regards,
KMB
Welcome, I dont know how active the Madison area is... aka, I dont think there is much of a Madison area lotus presence... however you're still in a decent area that isn't too far from where most of us are in the SE part of the state.
there is a cars & coffee in Waukesha that has its first season's show on April 15th (maybe 45 minutes east of you?) that should likely have a few lotus owners there if the weather holds up). I'll be there with my Elise if there isn't any fresh salt on the roads
you kinda missed the active glory years of the lotus owners group in northern IL & southern WI that seemed to hit a peak a few years ago & has died off since. but many of us are still around, just laying a little lower nowadays. :shrug:
These are brilliant cars; loads of fun. Congrats.
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
3. The early cars came with misaimed and dim headlights. If you drive at night, convert to HIDs. While better than stock halogen bulbs are available, HIDs throw more light. Stay around 5000k.
5. The best transmission lube I’ve found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
6. As per some engine builders on these sites, wait AT LEAST 20 minutes after coolant has reached full operating temp before engaging cam switchover.
7. Rear toe-links can loosen and break with disastrous results. You can check tq periodically, or use Nordlock washers. Best is conversion to better engineered brace, such as BOE’s for one example.
http://www.lotustalk.com/forums/f311/cooling-ticking-timebomb-how-your-cooling-u-tube-47232/
http://www.lotustalk.com/forums/f320/remote-key-fob-immobilizer-misc-alarm-programming-70940/
Some on this site are a bit obsessed with hockey pucks for lifting the car. Don’t use these. Too hard and slippery, generally, and too small a surface area. Use a piece of wood, as your hero does.
13. Visit the Uber Thread
http://www.lotustalk.com/forums/f3/elise-exige-uberpost-read-everything-you-need-know-here-25131/
14. Most parts on the car are made by Toyota and others, so buying things like a/c compressors, engine parts, etc. is wildly expensive when purchased thru Lotus.
Plus:
http://www.lotustalk.com/forums/f101/how-bleed-brakes-241138/
How to Search:
Transmission Fluid change what bolt site:lotustalk.com no space betw site:lotustalk.com
Happy To Be Here
Welcome to the forum! Until recently, I was in Fond du Lac and would lead some spirited drives. My favorite one was down in the Spring Green/New Glarus area, not far from you. Keep an eye on this section as Brian might become the new host of spirited drives. Mat is right that the area was more active a few years ago and even more active before I bought my car in 2013. That doesn’t mean you can’t have fun with mixed car groups though. If you’re interested in some of my routes, I can shoot them your way in an email and you can test out that new vehicle.
Also, post up some pictures!!!
Welcome! Where are you located at? I'm in the Janesville area. There's a few Lotus cars running around in Madison, but most seem to not be active on the forums.
We usually make it out to cars and coffee in Lake Mills most months, and occasionally do an impromptu drive out west of Mt Horeb in the hills. Track days at Blackhawk Farms too!
Welcome to ownership! I'm north of Milwaukee a bit in West Bend, so not exactly close, but I do try to make it to a C&C or cruise night here and there.
I'm in Madison. Just picked up a 2013 Evora S. I'm also trying to get a sense of what the Lotus scene is around here.
I grew up in fort atkinson, every time I come home to visit family I wish I could bring my car.
Nice to see there are actually some owners around,.
Seems like there aren't too many of us.
Busy lives keep a lot of us from the weekend gatherings. My wife won't let me be an absentee father. :(
Congrats! Milwaukee here...
I'm in Minnesota, twin cities. I feel I might be the only elise owner around here as well haha. If you ever come this way, shoot me a PM, I'm glad to meet! Even if you're only coming half way for any reason, like going to Eua Claire for some quarter mile drags at Rock Falls or something, I'd be happy to come meet you.
Happy To Be Here
I’m up in Warroad, MN, now and I’ll be heading the MNCEC show that’s on June 30th. I was selected to be in the show, so look for my gray Evora, I’ll keep an eye out for an Elise if you can make it!
Otherwise, I’ll probably be trying to make it to car shows in the TRF and Bemidji area.
Long period of silence from me, but we've miraculously landed in Eau Claire, and the Elise is still with us. Been here about 3.5 years, but haven't had the occasion to take the car out enough for any decent road trip save one back to Ohio. I keep hearing about the roads between EC and places like Alma, Buffalo City, and even as far as New Glarus. Just haven't made it that way. There's a Chippewa Valley C&C up here (third Saturday morning of each month) from April through September which has a relatively small but friendly following. For consistent British-ness, I see the Minnesota MG Club's well-attended "Rally in the Valley" out of a hotel on the west side of town each summer. There's one other Elise (very nice BOE supercharger setup) in town I'm aware of, owned by a gentleman whose name escapes me. We've run into each other maybe twice at the C&Cs, never out on the road. Too funny.
Welcome to the joy of your car! Hope I can make it south towards more of the Lotus activity at some point and run into you in Madison.
1 - 14 of 14 Posts
