1 - 17 of 17 Posts
2008 lotus elise
Hello All,
I am please to say that I bought a 2008 Lotus Elise recently and am very pleased to be the new owner. I was not sure in the beginning - first true drivers car. However, I am loving every minute of my back breaking experiencing ( getting in/out and just the drive.
I am a super noob, however, researching this forum in order to possibly perform the following (super charger, fly wheel, clutch, exhaust, cams, and more).
Added her brother from another - 911 GTS.
2011 Exige S260 Sport
Sweet Elise!
Welcome. There is a lot to learn about these cars and most of it can be found on this site.
Hello All,
Climbing in and out will get easier as you learn. Much easier if the roof is off.
2006 Exige K24A2 SC
Welcome. Lots of us from Oregon here. I'd love to hear the contrast to the 911 GTS, after making the comment "first true drivers car". I was actually considering a 991 GTS at the same time as buying the Exige. Pre-Covid did you ever make the drive up to Portland Cars and Coffee?
2006 Lotus Elise
This is has been much discussed, and everyone seems to think their way is the best way, but I've always gotten in like so: right leg in, use wheel for support, drop butt down into seat, pull left leg over sill and in.
To get out, left leg out, use wheel and sill to push yourself out, stand up and pull right leg out.
It's part of what makes these cars special.
Good company to keep.
welcome to LT.
Administrator
Welcome to LT! Congrats on your Elise purchase.
Hello All,
Congratulations this site has the best information around. Welcome
07 Aspen White Exige S - MT
Welcome, and if you’re planning on some of those things you mentioned. Few of them are quite big projects so be prepared.
Sounds like this “excuse me”….
Get something such as a Stebel Nautilus. Or, from beloved parts supplier, RD Enterprises: Compact Air Horn $59
Ultra Compact two-tone air horn unit measures about 4-3/8" tall x 5" long x 3" wide and weighs under 2 lbs., and it's LOUD! The sound measured at 2 meters is 115 dB. Easy installation because there's only one part to install, horn compressor relay and instructions included.
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
These (lube, mods) make a huge change in shifting. I also reoriented one swivel joint.
7. Rear toe-links can loosen and break with disastrous results. You can check tq periodically, or use Nordlock washers. Best is conversion to better engineered brace, such as BOE’s and InoKinetic’s for two examples.
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need...
18. Many benefits to joining Lotus Ltd (USA Lotus club). Get help wherever you are, using the contact booklet they update every year. (I’ve helped a few ppl who contacted me.) This is who stages LOGs (Lotus Owner Gatherings) every year. https://lotusltd.com
Plus, “How to bleed brakes”:
Maintenance and Repairs.
How to Search:
Pretty much everything you need for upgrades can be had from BOE. Their supercharger kits are the best. Upgraded 3rd and 4th gears in an LSD differential and an upgraded clutch with a light weight flywheel are all good stuff. LETSA shifter linkage and cables will make shifting much nicer. Adjustable Nitron shocks and springs will be good if you plan to go to the track. Be sure you have good toe link braces if you do any track work. A baffled oil pan and fuel tank are good to have for track work. Upgraded fuel pump will be needed if you go with a supercharger.
A fresnel lens at the top of the windshield will make it much easier to see traffic signals without ducking down. Replacement mirror glass for the right side is available which is an easy retrofit for the left side mirror too which will help with blind spot visibility. If you park in a garage or have a driveway gate a Homelink mirror is a handy thing to have. Its about the same size as the stock mirror (which is really too big), but it makes life so much easier going in and out of your garage.
Pretty sure you have already noticed the Elise has a much different feel than the Porsche. The lighter more agile and responsive feel will spoil you for any other car. A supercharger with intercooler will narrow the power gap that you will notice with the Porsche. A quick ratio steering rack is a nice addition too.
1960 190sl, 2000 M Coupe (RIP), 2001 Miata, 2018 Morgan three wheeler, 2005 Elise
Congrats on the purchase - another Oregon Elise just down the road from you!
You will find all you need here in these pages to answer most of your questions.
BMW club in PDX might still have slots open for this Thursday's track day if you are wanting to get out there!
1 - 17 of 17 Posts
