1 - 14 of 14 Posts
Welcome!! Nice color too.
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need to know is in here**
Plus, “How to bleed brakes”:
How to Bleed Brakes
How to Search:
I am v
5. Transmission:
And, use:
How to Bleed Brakes
How to Search:
I am very grateful GLB! Thank You!
Were you just driving by Indian Rocks beach the other day? Me and my GF were in my Evora next an Elise that same color.
HA! Yes sir - that was me! What are the chances!
We waved at each other! Nice car you have! Would love to get out together.
Discussion Starter #11
hey man; have you joined the Lotus of Tampa Bay Facebook Page? If not; you should.
talk soon / car ride!
1 - 14 of 14 Posts
