New Review, good for a chuckle.
1471 18
Okay, its in Dutch. I don't speak Dutch, so I used Babelfish:
AutoZine Elise Review
Behind the wheel wheel only the highest necessary bells are find. Matter such as the fuel meter and engine temperature are digitally reflected to save weight. The some extra are a candle end at the revolution counter which indicates the optimum link moment at warm engine. Elise II get in something easier have become than at the previous copy in the lotus. Although it is still more skilful firstly in the car will stand and then with the hands above the windshield in the chair fall, it is now also possible "normal" get in.
Steve
1 - 19 of 19 Posts
can someone please fix dat wit da shizzolator so I can understand it n' ****?
This took some serious hoop jumping, so I'm gonna post the text, not the URL.
Lotus Elise II
The Second da bests
"as something, repairs that shiznit then not",sounds da gezegde is not n' ****. Toch lotus took risk 'n renewed recently its largest success number, know what I'm sayin'? The previous lotus Elise wuz welhaast da sportwagen perfect, wit a pure uncomplicated character 'n records irradiation, know what I'm sayin'? Now da Elise wit da computer herontworpen are n' ****. Thereby da customers 'n da hooptie that shiznit has been well listened on da requested points has exactly improved whereas da character has remained."
One thing has, however, changed da character of da Elise: external n' ****. Whereas da previous Elise records had irradiation, da new hooptie looks simply aggressive." To da sharp lines, fel looking at heezee lamps 'n high incurring back let no doubt concerning exist there that this a sportwagen of da first order is n' ****. At every element of da design wuz weight saving at issue." The credo of lotus oprichter Colin Chapman sounds, as that shiznit happens,: "light are right" n' ****. It is thus extra admirable that da illustrators there as if wuz in its successful a oogstrelend fraai interieur minimum tricks make wit this way little material n' ****. Although da hooptie strictly speaking not even has a dashboard, da interieur has been neatly looked after." Thus a part of da plate work has been held wit gentle plastic panels of which da colours return in da lining of are based on."
Behind da wheel wheel only da highest necessary bells are find n' ****. Matter such as da fuel meter 'n engine temperature are digitally reflected save weight." The some extra are a candle end at da revolution counter which indicates da optimum link moment at warm engine, know what I'm sayin'? Elise II get in something easier has become than at da previous copy in da lotus." Although that shiznit is still mo' skilful firstly in da hooptie will stand 'n then wit da hands above da windshield in da chair fall, that shiznit is now also possible "normal" get in n' ****. Weight save is only da driver chair adjustable 'n provides wit inflatable lendensteun n' ****. Are based on colours well at da interieur, give much support 'n are this way hard that da driver can insure himself of that shiznit of da onderstel loudly 'n clearly every indicator catch."
At a sportwagen if da lotus Elise stands communication first, so that da driver can obtain that shiznit optimum from da hooptie." That not only becomes clear from "comfort" of is based on, but also from da onderstel hard as a rock, know what I'm sayin'? During da first kilometres even only doubt arises if da hooptie, however, has vering, but how longer da test ride lasts how da mo' driver will appreciate da onderstel." Control has not been ratified hella direct 'n as vanouds, so that da driver can sense da hooptie again perfectly 'n well can assess which da hooptie is afiable n' ****. And that is much n' ****.
The position 'n wendbaarheid of da previous Elise wuz already sublime, da new Elise omit themselves still better sense 'n da borders lie still further." Moreover lotus lets know that da new Elise are less staartlastig at rain n' ****. By da broad they panels in da interieur da hooptie feels broader 'n larger than da predecessor." ABS, tractiecontrole or ('n that is in this context almost curses in da church) stability control reduces da file pleasure fo' da real lotus-rijderlotus-rijder lotus-rijder only 'n has been therefore in default left n' ****. Moreover such spelbrekers make da hooptie only heavier 'n wit that less rapidly."
Jet HUNTER
Thanks izzall weight saving da Elise II bring just as wide 700 kilogrammes on da scale, know what I'm sayin'? For this reason is 'nuff engine da same relatively light such as also in da previous Elise wuz find: 1.8-liter a four cylinder of rover n' ****. Of course lotus has, however, adapted da strength source its own requirements, whereupon eventual 122 paardekrachten on da rear wheels are released n' ****. That seems perhaps number records, but which lotus has a beetje weet that da hooptie wit that hella spectacular things afiable is n' ****. Already at ordinary drive da driver has ongoing da feeling that in da back a rocket engine is ready fire da hooptie at everyone desired moment." Also at low go fo' a ride da docility of da engine is enormously 'n is clear that this a volbloed sportwagen is wit onstilbare a hunger speed n' ****. That hunger gots be satisfied, know what I'm sayin'? The sprint of 0 100 km/uuu costs according lotus 5.7 seconden 'n is this way spectacular that one jet hunter pilot could himself wish mo' n' ****.
If that shiznit engine sound goes da jet hunter pilot will even has no wishes." As soon as da Elise can go fo' a ride make, dooms a raw sound of behind da voorstoelen on that directly a circuit ambiance gives n' ****. Then da Elise are an adrenalin pump on wheels." With open roof file wind is well audible 'n that makes wit da hella low zit da sensation complete." Thereby comes that close-ratio perfectly connect da acceleration barge at engine behaviour 'n da inzittenden are fired alsware that shiznit a catapult, know what I'm sayin'? Then da Elise seem not particularly faster than da remaining movement, that shiznit seems as if wit da Elise between a motorway full pedestrians gots be manoeuvred by! Fortunately hears izzall that capacity a formidabele set ho-houders, know what I'm sayin'? Such as belongs a pure sportwagen if these, those brakes has not been ratified n' ****. Tha dude who that not accustomed is many autoliefhebber think never mo' differently want at da first familiarisation that da brakes are faulty, but after even sense n' ****. Correctly by interrupting assistance da communication line 100% is purifies, know what I'm sayin'? Stopper strength is dose impressively 'n perfectly, know what I'm sayin'? But then becomes brakes no speed reduces stopping da hooptie on da desired spot." The brakes give a large faith in da hooptie, so that every ride invites up mo', know what I'm sayin'?
CONCLUSION
Lotus has taken a large risk by radically taking a hella well selling 'n performing sportwagen under hands, know what I'm sayin'? Fortunately also da second generation of da lotus Elise is a sportwagen in its pure form n' ****. If that shiznit purifies 'n uncomplicated file pleasure goes, lotus has succeeded perfect in da perfection." At da latest is appropriate now improve at da performances, da hooptie a fractie has become mo' functional, finishing signaling better 'n da concept answers still better da wishes of da purchaserpurchaser purchaser, know what I'm sayin'? The lotus Elise II gives still feeling of wendbaarheid, agility 'n speed onovertroffen 'n gives wit that izzall other sport carriages litterally 'n figuratively following, know what I'm sayin'?
I run a dutch forum... I will ask for a better translation. :)
Thanks Arno, I forgot we had our resident Dutchie. The people on the other forum are trying to teach me all things Dutch including learning foods like zuurkoolstamppot and boerenkoolstamppot and erwtensoep.....and something about a limburg cheery crumble flan....and the most important.. hangop.
Mmmm.... hangop.
Mmmm.... hangop.
Be careful about accepting translations from the Dutch they have a strange sense of humour. I spent about 3 months when I was 18 in Holland and had been taught a few useful Dutch phrases by a dutch friend before I went. It took me a while to realise that when I thought I was saying "Hello, Good Morning" I was actually saying "Hello, I'm a fried egg".
rotfl :clap:
Actually, even though it's Dutch, the encheferizer does a surprisingly good job of making it more intelligible:
Beheend zee vheel vheel oonly zee heeghest necessery bells ere-a feend. Bork bork bork! Metter sooch es zee fooel meter und ingeene-a temperetoore-a ere-a deegitelly refflected tu sefe-a veeeght. Um de hur de hur de hur. Zee sume-a ixtra ere-a a cundle-a ind et zee refulooshun cuoonter vheech indeecetes zee oopteemoom leenk mument et verm ingeene-a. Ileese-a II get in sumetheeng ieseeer hefe-a becume-a thun et zee prefeeuoos cupy in zee lutoos. Um gesh dee bork, bork! Elthuoogh it is steell mure-a skeelffool furstly in zee cer veell stund und zeen veet zee hunds ebufe-a zee veendshield in zee cheur fell, it is noo elsu pusseeble-a "nurmel" get in. Bork bork bork!
Need4Speed said:
Randy, WhenTF do you sleep??
Last night being an example, between 2:35am and 6:45am. The good thing is I don't have to do much on the Dutch forum stuff. I have no idea what they are talking about so we have Dutch moderators. And now a German section too. Wie Gehts.
1 - 19 of 19 Posts
