1 - 18 of 18 Posts
2006 Lotus Exige
Hi All,
I just bought my first Lotus. Its a 2006 Exige. I believe it is @Tasracer old Exige. It should be delivered Monday.
I come from the MINI world. I own a JCW coupe that has been extensively modded. I am looking forwarded to driving a car that is about 900lb lighter. I am an old fart gear head. I also have a few Bikes old and new.
I thought I would join to help learn about my Exige, sense I do all my work I am sure I will have questions along the way.
Ill post pictures when I get the car for now this is the JCW
1264242
Administrator
Welcome and I bet that you're chomping at the bit waiting for your new car!
Congrats & welcome to the Lotus world where there's NO return. Where are you based?
Post a few pics when you have a chance.
Cheers,
Kiyoshi
2006 Lotus Exige
@Catsailr27 I am chomping at the bit. On top of it I have never driven one. I just hope I can get in the dang thing.
@khamai I am in Memphis. I will post some pictures as soon as it shows up.
Administrator
2010 Exige S260
Welcome to our community! You will love your Exige!
Memphis! Nice, I’m in Bartlett, it’s nice to have another Lotus around, there’s not many here!
Tons of fun ahead for you......OK, only 1 ton.
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need...
Plus, “How to bleed brakes”:
How to Bleed Brakes
How to Search:
2006 Lotus Exige
Thanks for the welcoms everyone!
@cirving I am also in Bartlett. Small world
@glb Thanks for that list, it will be very handy.
Congratulations on your new purchase.
I also bought my Exige without test driving one. It is what every review says: raw and direct. Since you are into bikes, you will most likely love it too.
2006 Lotus Exige
Discussion Starter #11
I hope so. I have had both a Gen1 Mini and Gen2. My Gen2 has a turbo and is more refined. The Gen1 was more visceral, you were more connected to the road. I really miss the super charger wine of my Gen 1. Raw and direct sounds great. I really cant wait. It will be a long weekend.
2006 Lotus Exige
Discussion Starter #12
Just got a call from the shipper. He had to slide the delivery by 2 days but I will be out of town. Now it is going to be delivered on Friday. It will be a long week.
Friday? That’s too long to wait! The Local British car club is having a rally Sunday in the Bartlett area if you want to accidentally drop by ;)
BTW, I’ve got a four post lift if you need to inspect under your car when you finally get it
Reactions: 06LE
2006 Lotus Exige
Discussion Starter #14
Thanks for the offer. I may take you up on it when the car shows up. The Rally sounds fun. If I can brake away a black JCW may show up
1 - 18 of 18 Posts
