1 - 13 of 13 Posts
Proud new owner of a 2007 Exige S in black. This has been a long time coming, previous Porsche and STI owner. Been without a proper sports car for 15 years, not the case anymore!! :cool: 12k miles and she's a stunner!! Looking forward to using the knowledge base here on the forum!
Automotive parking light Land vehicle Wheel Car Vehicle
it is... a beautiful ride. Enjoy and congratulation! Mind sharing where you were searching as I am still hunting for one?
Thanks Y26 and Reeser! I was seconds from pulling the trigger on an Evora in CA and thought I'd check eBay for the heck of it. The listing popped up with 15min left and after a quick look and a bid that I was sorta sure wouldn't meet reserve, I was the high bidder. So happens the car was an hour from me in Springfield Mo so i was able to inspect before purchase. So I guess it was meant to be. I was in the market for an Evora or Exige and had not found many Exige out there. There is one on Bring a Trailer right now...
Administrator
Welcome to LT Jilm!
Reactions: BigJilm
Nice!!!
1. These cars have large (i.e. dangerous) blind spots. Multivex mirrors are NLA, but RLS (Really Light Stuff) offers very good tape-on replacements/. GRP (Greg’s Racing Parrs) offers Extend -a-View mirrors, but I’ve not seen them.
Sounds like this “excuse me”….
Get something such as a Stebel Nautilus. Or, from beloved parts supplier, RD Enterprises: Compact Air Horn $59
Ultra Compact two-tone air horn unit measures about 4-3/8" tall x 5" long x 3" wide and weighs under 2 lbs., and it's LOUD! The sound measured at 2 meters is 115 dB. Easy installation because there's only one part to install, horn compressor relay and instructions included.
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
These (lube, mods) make a huge change in shifting. I also reoriented one swivel joint.
6. As per some engine builders on these sites, wait AT LEAST 20 -35 minutes after coolant has reached full operating temp before engaging cam switchover.
7. Rear toe-links can loosen and break with disastrous results. You can check tq periodically, or use Nordlock washers. Best is conversion to better engineered brace, such as BOE’s and InoKinetic’s for two examples.
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need...
18. Many benefits to joining Lotus Ltd (USA Lotus club). Get help wherever you are, using the contact booklet they update every year. (I’ve helped a few ppl who contacted me.) This is who stages LOGs (Lotus Owner Gatherings) every year. https://lotusltd.com
Plus, “How to bleed brakes”:
Maintenance and Repairs.
How to Search:
no space between site: lotustalk.com
Congrats! And welcome to the forums. Oh, and love the Boognish avatar :D BigJilm! Some OG Ween right there. A man of great taste in cars AND music.
shay2nak
Congrats!
Post more pics!
Reactions: BigJilm
Discussion Starter · #12 ·
Thanks everyone for the positive comments! Funny someone mentioned the wheels, that will be my first change to the car. Not a big fan of the wheels and will probably try to find a set of cup wheels. The CCW's are beautiful but just not my cup of tea and I prefer staggered over the square setup. Anyone interested keep an eye out, as soon as I have enough posts they are going in the classifieds for sale or trade. I have the original wheels and those are getting new Yoko 52's today.
1 - 13 of 13 Posts
