1 - 9 of 9 Posts
Hi All!
I just picked up my Exige last week.
Was looking for a few months, and found a local California car just a few miles away from my home.
I'm located in the Peninsula, San Mateo area.
Looking forward to future GG Lotus club meetings, whenever that is.
-Geoff
Good for you!
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need to know is in here**
Plus, “How to bleed brakes”:
How to Bleed Brakes
How to Search:
Thanks for the welcome all!
And thanks for the tips, @ GLB
Sorry for the crap garage pics. I only had time to pick up the car from the seller and tuck it away. Back to work, kids, and weird covid time of life. Hoping to get time in the upcoming week to go over the car, clean up, baseline maintenance, and drive. Subaru and AE86 will keep it company for now.
Glad you got it to save me from it...lol No room, but someday would maybe like a stock S240 or Elise SC. (I saw it listed some time back, and then again saw it a few days ago.)
Congrats!
1 - 9 of 9 Posts
