1 - 13 of 13 Posts
I just got a 2005 Elise delivered. I have zero history, so before a first drive, I'm doing all the maintenance things on it. I ran into a few questions when looking under the front clam.
  • First, there are plastic fittings going into the brake master cylinder. Both are broke (meaning the reservoir is empty). Glad I didn't try to drive it... :eek: When I look up master cylinders, the pictures don't show these plastic pieces. But I can't find them separately, either. Where can I get them? I'm dead in the water without this.
  • Second, there is a box under there that is broken/melted (see attached picture). What is this?
  • Finally, when looking in front of the tire in the passenger's side (right) wheel well, I can see an AC line. It looks like there is a plug or something in it which might be broken. What is this? (see attached)
It looks like I'm also going to need the torx-style tool to pull the wheels off since the car didn't come with a tool kit. If anybody has ideas on where to buy one, I'm all ears.
Thanks!
1. Are the lines broken or just not plugged in, they actually come in and out of the reservoir pretty easy. If they are broke I think you're going to have to get a new reservoir if you're in a hurry but id doesn't NEED to be OEM.
2. That looks like a resistor pack box that has been relocated to that area so when it fails in the future its not a 6 hour job to change it.
3. That is a AC service port, that has been bent for sure, but if it's not leaking then it is what it is.
Someone will come on here with the tool available for sale They are in the $20s normally. I just use studs and nuts now.
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
3. The early cars came with misaimed and dim headlights. If you drive at night, convert to HIDs. While better than stock halogen bulbs are available, HIDs throw more light. Stay around 5000k.
5. The best transmission lube I’ve found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
And, use:
6. As per some engine builders on these sites, wait AT LEAST 20 minutes after coolant has reached full operating temp before engaging cam switchover.
For street cars, consider removing one or both oil coolers. Some cover them.
http://www.lotustalk.com/forums/f311/cooling-ticking-timebomb-how-your-cooling-u-tube-47232/
http://www.lotustalk.com/forums/f320/remote-key-fob-immobilizer-misc-alarm-programming-70940/
14. Visit the Uber Thread
http://www.lotustalk.com/forums/f3/elise-exige-uberpost-read-everything-you-need-know-here-25131/
15. Most parts on the car are made by Toyota and others, so buying things like a/c compressors, engine parts, etc. is wildly expensive when purchased thru Lotus.
16. The soft high-grip tires on most of our cars lose much of that grip when temperatures drop below 50 F. I know of too many ppl who spun their cars when not remembering this. I use hi-performance all-seasons.
Plus, “How to bleed brakes”:
http://www.lotustalk.com/forums/f101/how-bleed-brakes-241138/
How to Search:
Transmission Fluid change what bolt site:lotustalk.com no space betw site:lotustalk.com
Did this thing get in a n accident, bent AC, broken brake reservoir....
if all else fails, the dealer has the wheel tool, not worse than you would expect pricewise
So will the plastic pieces come with the reservoir rather than the master cylinder?
Where to the resistor packs come from (I'm assuming not OEM since it looks added on)?
I thought maybe the part in the AC line was a pressure switch or something with the electrical connection broken off. The line looks much more bent in the picture than it is, so I'm not concerned about that. I just don't have working AC, and am trying to hunt obvious stuff first.
Thanks for the replies.
The resistor pack is to set the fan speeds on the HVAC fan. They fail in their oem location so people move them.
Why doesn't AC work. You need to give more to work with, no fan, not cold, compressor never kicks on, etc? I don't think there are any electrical connections to the AC piping up there? It's been a while since it was in my car.
Im not 100% sure what pieces that are broke I guess. Pictures man, try to help.
I got a new torx-style lug nut tool from Lotus of Greenville. If you don't want to wait for somebody on LotusTalk to sell you their's, Lotus of Greenville will order it for you and mail it to you. I honestly can't remember what I paid for it, but I don't remember it being stupid expensive. Ask for Robert Davies.
Robert Davies
Maserati Lotus Greenville
1450 Laurens Road
Greenville, SC 29607
(864) 255-3593 Office
(864) 235-3068 Fax
www.maseratilotusgreenville.com
I haven't gotten into sorting through the AC yet. For now, I'm just trying to identify parts and get an assessment. I'll do my research when I get to it and ask more specific questions. So if the fan speeds work, this resistor pack is ok? Thanks for the answers.
I’m in Springfield, MO. One of the 5 Elise’s not in CA, lol!
There's quite a few of us running around Missouri. Local to me (the KC area) has more than I expected. Good luck with the repairs, I hope you at least had a little knowledge of what you were getting before it arrived.
Discussion Starter #13
Fortunately (unfortunately?), this isn't my first rodeo - as we say in this part of the country. I just finished a 3-year full restoration on a '68 Corvette. The Elise isn't really a project. Just has a few things I need to address before putting into daily use. Good to know there are a few around here. The last time I saw one on the street was at least 3 years ago.
1 - 13 of 13 Posts
