1 - 20 of 24 Posts
I picked up my first ever Lotus last week. I've had many Corvette's Porsche's BMW's etc... But this! Driving a Lotus is unlike anything I have ever experienced, far different than even the GT3. It lets you "feel" the road, you become part of the car! Anyways I just wanted to thank everyone here. I have been a lurker for years. I was skeptical of the "low hp" but over time I got more and more curious. I'm SO glad I kept reading posts and finally decided on a test drive. Bought it on the spot. THANK YOU LOTUS TALK! :D
Less is Better
I don't know about underrated. Every magazine who reviewed the Elise gushed over it, they have a stellar reputation for handling and owners mostly plan to keep them. But yup. 2000 pounds is truly unique these days and no modern "sports car" (They're all really GTs) can provide the same experience.
So true, I can't believe how stuck to the road it is. You can only appreciate it by driving one. Mine does not have the oil line recall done. Is it a hard job if I pay a independent to do it? I'd prefer not to take it to SF for service, I work almost every day.
I foresee lots of fun in your future.
Good for you!
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need...
Plus, “How to bleed brakes”:
How to Bleed Brakes
How to Search:
Less is Better
Before Lotus did the recall, some folks did upgrades to the fittings on their own. It's doable, but I'd first reach out to Lotus and tell them the situation to see if they can work something out with your indie. I've found Lotus to be responsive to emails.
Less is Better
Here's an aftermarket kit
Yeah, I'd try to go through Lotus somehow. If anything goes wrong, it could easily mean a motor replacement or worse, and I'd want the insurance.
You should really have a Lotus Dealer do the oil line recall. It is free (warranty) and it’s guaranteed by Lotus.
Lotus will not let an independent shop do the work as there are very special and expensive tools that must be used to insure the oil line hose clamps are installed at the proper tightness. (I tried, they said no).
Nothing drives like a Lotus. Glad to hear you now have religion :cool:
Reactions: Mitchrvguy
Congrats and welcome! I agree on the "underrated" only because the public has been conditioned to look at hp numbers... not vehicle weights when it comes to performance. Find a twisty mountain or canyon road and you will be hard pressed to find ANY car that feels more like it was "built" for that road!
Enjoy!
1. GLB is a genius.
2. What GLB said about using a diesel engine's oil in your gas engine may seem strange... but GLB is correct.
3. Now that you understand 'underrated' I hope you realize it's more important to learn from those that have the knowledge of how to DRIVE the car, instead of hanging around people who instead TALK about the parts/mods they're going to do to their cars so as to later maybe, repeat maybe, be faster after they "improved" the car. The expression is: speed will come.
....but only if you learn to drive it.. . and there's no substitute for seat time.....but for what you've owned before, to give you a little credit, you may already know this
EYERACE.com
shay2nak
Congrats! Low HP is only temporary. lol
I always tell people, don't drive it, because you will want to buy it. ;)
Welcome Mitch,
Hope you continue to enjoy your new Lotus. It's only been a near 60 year obsession with me. Glad to you found how connected to the road a Lotus can be.
To steal shamelessly and rip off a quote from Peter Egan, "Lotusing makes a heroin addiction seem like a vague wish for something salty."
Regards,
Dan
Discussion Starter #15
Guess I'll take a day off and have Lotus do the recall. :) I'm taking it in Monday to get a new stereo with a 4 way amp and focal's front and back. Should fix the radio issue for good. :D
I have Sony DSX-GS80 45 watt per channel head end, Focal PC100 front speakers and Focal PC130 rear speakers.
You still need a sub so run the wiring for future use.
Just saying......
By now I hope you've twice printed off the 17 points GLB posted and left one in the car for occasional reference and the other is under your pillow for when you sleep
2006 Exige
Look into fitting larger speakers before you take it in there. You can size up front and back, but it requires some modding.
Does Stan's Mod serve the same purpose a the Re-Enforcer kit from Inokinetic? Meaning, would one do either of the mod, but not both?
Thanks,
They are quite similar. I don't recall the Stan mod requiring drilling, just making use of what's already there, and adding a bolt. The Re-inforcer does need you to drill.
1 - 20 of 24 Posts
