Improved gear shift cable
SSC Improved Gear shift cable - for Toyota Lotus Elise & Exige
Simply Sports Cars Australia, has developed a new shift cable as a direct replacement for the factory cable. We needed a stronger cable that could cope with race conditions while having a more positive engagement feel. The result is a cable that is stronger, has less lost motion, and is smoother in operation.
Main features:
At the gear shift end –
Brass nickel plated guide sleeves with dust seals, instead of plastic guides with no seals – provides better guidance of side loads.
Terminates with low friction Teflon lined Spherical Rod ends – and eliminates ball linkage shear at the gearstick.
At the gearbox end -
Larger operating rod with brass nickel plated guide sleeve instead of plastic –
providing smoother operation with a higher load capacity.
Increased longevity with double protection neoprene boots providing a dust- proof seal, instead of a single gaiter.
The Cable -
Low friction inner cable provides higher efficiency, reduced force, and minimised backlash, for a smoother operation.
The cable design incorporates a splined core allowing a close low-friction fit with the inner cable liner to reduce play.
Components -
(See picture)
This single cable is to be used in conjunction with the other factory Crossgate cable.
Fitting instructions included.
Available now from Blackwatch Racing (BWR) for US/Can markets. Other markets email us for price and freight.
[email protected]
Main features:
The Cable -
Components -
(See picture)
[email protected]
