1 - 13 of 13 Posts
Come on, you can do a better intro than that! Where's the effort? Where are the pics? Congrats on joining the club and welcome to the forums! :)
Congrats.
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
3. The early cars came with misaimed and dim headlights. If you drive at night, convert to HIDs. While better than stock halogen bulbs are available, HIDs throw more light. Stay around 5000k.
5. The best transmission lube I’ve found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
And, use:
6. As per some engine builders on these sites, wait AT LEAST 20 minutes after coolant has reached full operating temp before engaging cam switchover.
For street cars, consider removing one or both oil coolers. Some cover them.
http://www.lotustalk.com/forums/f311/cooling-ticking-timebomb-how-your-cooling-u-tube-47232/
http://www.lotustalk.com/forums/f320/remote-key-fob-immobilizer-misc-alarm-programming-70940/
14. Visit the Uber Thread
http://www.lotustalk.com/forums/f3/elise-exige-uberpost-read-everything-you-need-know-here-25131/
15. Most parts on the car are made by Toyota and others, so buying things like a/c compressors, engine parts, etc. is wildly expensive when purchased thru Lotus.
16. The soft high-grip tires on most of our cars lose much of that grip when temperatures drop below 50 F. I know of too many ppl who spun their cars when not remembering this. I use hi-performance all-seasons.
Plus, “How to bleed brakes”:
http://www.lotustalk.com/forums/f101/how-bleed-brakes-241138/
How to Search:
Transmission Fluid change what bolt site:lotustalk.com no space betw site:lotustalk.com
shay2nak
Congrats!
2006 Lotus Elise BRG
Love the stripes and of course the BRG. Congratulations. Took mine out for the first ride of the season today. Going to Lime Rock next weekend for the Car Control Clinic.
Love your car! I waited 9 months for a 60th anniversary edition to become available. I finally got one this past August. I love the 60th edition because it comes with Sport/Touring/Track packages, a super charger, and the Exige seats with the the logo stitched into the headrest. Absolutely the best Elise you get get if you ask for my biased opinion. :) Everybody has different opinion about modifications but here's what I did to mine:
1) New aluminum radiator
2) Inokinetic ShifterR (naked so you can see the mechanism) and new cables.
3) Inokinetic pedals for easier heel/toe.
4) Two-piece Ultradisc rotors
5) SonicFury exhaust (less drone than Larini and awesome sound)
6) MWR Lift Point Kit (to easily lift Elise with 4-point lift)
7) New engine mounts to improve shifting
8) Stainless steel brake lines
9) Harness bar and Schroth 4-point belts (in silver to match silver stripes on car).
10) Nano ceramic coating to entire exterior paint.
1 - 13 of 13 Posts
