Nice.
Sounds like this “excuse me”….
Stebel:
“HONK! LOOK OUT!”
5. Transmission:
a) Early cars have wobbly shift towers. Look up Stan’s Mod (bolt and spacer;
http://www.billswebspace.com/ShifterReinforcement.pdf) and
And, use:
These (lube, mods) make a huge change in shifting. I also reoriented one swivel joint.
6. As per some engine builders on these sites, wait AT LEAST 20 -35 minutes
aftercoolant has reached full operating temp before engaging cam switchover.
So I’ve been pretty quite as of late and don’t think I’ve seen this cooling issue addressed before. This last Friday I discovered a small cooling leak originating from the front side of the engine of my Cartoon Car. So I took the undertray off and slid under to take a look at what might be the...
www.lotustalk.com
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need...
18. Many benefits to joining Lotus Ltd (USA Lotus club).
Get help wherever you are, using the contact booklet they update every year. (I’ve helped a few ppl who contacted me.) This is who stages LOGs (Lotus Owner Gatherings) every year.
https://lotusltd.com
Plus, “How to bleed brakes”:
Maintenance and Repairs.
Note that many people disagree with my method, so judge for yourself. Taught to me by semi-famous Toyota engineer, who built championship winning cars and bikes. 1. Get Sears brake bleed kit (canister, hoses, adaptors for bleed valves) and their hand vacuum pump. Kits there have both...
www.lotustalk.com
How to Search:
