It is relatively easy...key word is relatively. If you do not have any knowledge of how engines run i do not suggest tunign it yourself. Every system comes with a base map, but I always encourage people to share details about thier set up so we can better help them with the map. Maps for all the popular configurations are supported.I have some EFI questions before committing...
1. How does it affect emissions inspection, or OBD emissions testing, or whatever kind of testing is done at the time of inspection?
2. How difficult is it to install properly and un-install properly? Approximate labor time?
3. How difficult is it to tune?
That's all![]()
Valvespring upgrade = to prevent valve float at high revs?2. Yes. Clutch being #1. Valvesprings should be upgraded, but I would recommend that for anyone, stock or otherwise.
Springs will help but still not totally prevent float. There are several reports of 2ZZs floating valves with HD springs.Valvespring upgrade = to prevent valve float at high revs?
+1 I have seen 3 autocrossers break valves with rev limiter time of only a couple of seconds.This like the universal horsepower threadrotfl
The valves and springs are to help firm up the prone to float valvetrain. I would suggest that as people get more power, they use that as an opportunity to try and live below 8,000 and their motors will live a healthy life... There's plenty of NA and SC'ed mills that have floated valves, broke stems, etc in the above 8,000 rpm range on stock heads...
Best,
Phil
Time to roll the sleeves up tonight. Phil's kit just landed, and it looks awesome as expected.:shift:
why does an IC alter the throttle response?I hate the doughy throttle response inherent in an IC'd set-up, so the better adiabatic efficiency of the TVS is perfect.
