Next Generation in Supercharging Means 275whp!
383340 Views 2084 Replies 243 Participants Last post by  VanZong
5
As some of you know, we’ve been working hard integrating the TVS family of superchargers to 2ZZ Engine and our Lotus. The TVS blower is the new twin vortices blower from Eaton to replace the more archaic technology that most of us are running found in the MP-62. The results are simply fantastic!
These new blowers are VERY efficient and are even exceeding the efficiency envelope of the infamous Lysholm twin-screw! -eek- We’ve been experiencing performance on par and exceeding that of any air-to-air intercooled MP-62 supercharger system on the market with our NON-INTERCOOLED TVS system. The TVS is so efficient that charge temps and parasitic drag drop enough that at just 10psi boost, with a conservative timing map and properly rich AFRs, we’re seeing about 275wheel horse power and 175 wheel torque!:evil: :shift:
Comparing charge temps of our original setup with 10psi on a non-intercooled MP62 Katana base to our non intercooled TVS there is a drop by approximately 60+*F at peak load and full heat soaked conditions and over 100*F lower off load. Temperature recovery is much faster on this blower from my data logs. That means that when not under full load, temps drop faster and the unit cools faster, which mean an even greater *average* drop in temperature from the MP 62. Parasitic drag also drops with this unit. Another interesting note is that it’s whisper quiet as well…:cool:
Ultimately, we were able to get MP62 intercooled performance (better actually) without all the complex plumbing, weight, and throttle lag of the intercooled systems available today (both OEM and aftermarket).
Better news, yet!! This is the upgrade I think we were all waiting for (I certainly was)!:nanner: I worked very hard to ensure that this is a direct bolt on upgrade to the MP-62 based, non-intercooled, supercharger kits available today (BWR and Sector111’s Katana)! That means you won’t have to completely scrap all the hard earned dollars you spent on your first kit, as many of the bits are reused with our new system. You may even be able to sell your original MP62 to help recoup some cost.:D
We machine the TVS blower housing to fit the Lotus 2ZZ on our CNC mill, make custom pulleys, and adapter plates to fit the two manifold systems on the market today, and mill the bracketry from solid billet steel.
I'm obviously very excited about this. If the interest is there, we’ll work with existing vendors to bring this to the market as an upgrade and/or entirely new kit to the market.
TVS Information (from Eaton’s website): The Eaton Twin Vortices Series or Eaton TVS™ is a patented supercharger design that features twin four-lobe rotors, twisted 160 degrees. By comparison, the original Eaton supercharger features three lobes twisted 60 degrees. The fourth lobe and added twist, when combined with redesigned air inlet and outlet ports, creates a smoother, more efficient flow of air into the engine. In addition to improved overall efficiency, the Eaton TVS supercharger has improved noise and vibration characteristics as well. This is the same family of blower found in the new ZR-1 Corvette and CTS-V
The two dynos below are simply in two different scales. One shows the torque curve better and the other has "forced scaling", which how most dynos are posted... The CAD drawing is the alternator and blower support and the others are my engine bay...
Best,
Phil
See less See more
41 - 60 of 2085 Posts
Interested in a kit for a non-SC'd Elise.
Will there be a package for Exige S? Curious as to the cost and also installation.
+1 just showing my interest in the upgrade
good work phil, but why are you only getting 225/148 with a base katana at 10PSI and no cat ? Am i missing something obvious.
CX- I don't think you're missing anything, that's just what she laid down... Both Darksol and I had similar figures with our 10psi pulleys on the same dyno- same day. AFRs were fine at the time- that was before we all discovered the longterm big no-no pulley swap issue... At anyrate, Dark's car always had about 5 ponies more than mine since he had better headers and TB, etc... Last we checked (dyno'd) his car, he still had about the same power with the 3.4 pulley as well... The second chart showing about 241hp was still with the 10psi pulley, but I pulled the stops out and made that power by tuning for the "CA" intake (read, KN filter on the end of a tube) and adding some timing on the lower half of the pull... Based on that observation, the stock intake is a bottleneck- it just has to be tuned for if changed. Not sure if the Cup intake will fix that with tuning or not (simply meaning, not sure if the Cup intake flows enough add'l air over stock)... Different discussion for a different thread though...
Well, 500 hp from it? What's the realistic max before it becomes inefficient?
I don't think so... Well maybe. I know it's got the air for 400whp with an IC and built engine and still be within it's efficient window- But I'd be surprised if 450 or 500 is...
I've maxed the 440s out doing the 175wtq. I should have 550s sitting on the step when I get home tonight. My plan is to go ahead and pulley down to raise the boost to 12-14psi. If the charge temps stay within reason, then I should be at or close to 300whp and 200wtq. That will probably be it for me until an IC comes into play- if ever... Charge temps will be the deciding factor here. I'll add boost until they get funky and call it good.
The engine is a stock OEM Toyota short block with the 9:1 Mahle drop ins, so I built it for higher boost. The 10psi exercise that I posted here was to see what the blower could do for the high compression motors, as we know 10psi at reasonable charge temps is "runnable" on 91 gas and high compression. In all good theory, the higher comp motors (stock) should push the same if not a bit more HP than I did, as you certainly don't need 9:1 to run 10psi boost (as I've demonstrated with my old M62 setup). Again, I ran the same timing with this TVS 10psi as I did with the M62 at 10psi. THe M62 was bolted up to my stock compression engine. That means that I could have ran more timing with the TVS due to the lower compression and lower charge temps...
In otherwords, in *general*, assuming the same fuel, timing advance is a function of cylinder pressure and RPM. I had less cylinder pressure with the colder air and lower static compression, so I should have been running more timing to get peak power... Only concern at this point is if the 440 injectors have enough juice to get more power... It's questionable as the 440s are -just- big enough... Two more high compression cars are getting the TVS soon and they will be good reference points as well...
Best,
Phil
See less See more
Awesome results phil it really is impressive how far the Lotus community has come with charging over the last 12 months....
Im glad I waited and didnt jump at the bwr offer I had a feeling things were gonna get better...
Thanks for update Phil. Are you stopping at 300 whp because of chassis or something else?
Bring it out to CA so you can run on some tracks with me :)
I'm remarking about your 'costly' statement, a reflash from me for these types of kits costs $600 base, thats it nothing else is needed, it'll be safer and have as much power as the standalone stuff, and it'll pass sniffer and OBD II, you need an efi standalone, a harness, and tuning, which is considerably more, yes you can retune to your hearts content and if thats your goal you ought to install a standalone, but it'll cost a lot more in the long run.
i charge $100 ph at the dyno, for the intial tuning, if its not right or needs tweaking, i don't charge addtional fees, even if it needs a few times , i don't charge for street tuning either, and other people get the benefit of any custom tuning since i can provide those updates, the last time i did that it was $25.
i think those going the way of a standalone are being true to the spirit of the hacker, and i wholly support that, but as with life you're taking a tiny percentile.
I just don't see where you get 'costly' from, thats all
In other words...
Charlie is God...
And a great guy to do business with! :nanner2::nanner2::nanner2:
I will purchase, once there is an Exige S solution. Great job!!!
Would love to come out, it's only 20 hours or so drive!:eek: How about you bring your car to Kansas:D:D
The 300whp is just a guess... I'll add power until the charge temps start climbing out of control... The 4 lobe twin vortecies simply move air so much cooler/efficiently than the M62, that I'm hoping I can keep charge temps below 200F at even 12-14psi in 70 degree environment and fullly heat soaked (or atleast as much as I can get without being ont he track). If I can't hit 300 w/o an IC, then I can't- no big deal. The car is quite quick :cool: and very responsive as it sits with only 10psi boost...
The M62 would certainly have been in the 300*F charge temp arena at that 12-14 psi pressure (using my equipment), as it was pushing 240+ at just 10psi with ~70 degree temps. The TVS is only pushing 175 at 70 degree temps and it has less drag (drag: as advertised by the manufacturer, I have no way to substantiate this...)... Again, both in fully heat-soaked states. I'm only looking for a delta T here, as everyone's sensors seems to give different readings....
Thank goodness for a climate controlled dyno room. Winter is coming into the midwest! I'm relentless on the rollers. I drive the car hard before I get to the dyno and then do several pulls back to back without shutting the car down. I tune with the car idling every two pulls typically. Then pull a couple times and tune again. The guys at the dyno said I've got the second most pulls of all their customers, just short of the owner... That's hillarious... I think I'll get him knocked off his horse by next weekend;)
Back on topic, fortunately, I've got sensors all over the car and data logging ability, so I'll be able to see these temps very accurately as I strive for a track safe 300whp on a non-ICed TVS... I've got my glass half full, as I think it's doable without pushing it too hard:panic:
Best,
Phil
See less See more
As long as charge temperatures remain reasonable, should reliability be a problem?
You mean reliability of the engine? Should be. At 10psi, I know charge temps are fine and safe... I bet more safe temps than the M62 at 7 psi... I know Fred has like 370whp on his stock 2ZZ in his XP car, but he runs 112 race gas and auto crosses and the engine is still holding strong... I doubt our engines will last long at that power on the race track... But that's just speculation...
Point is that 275whp should be OK on the stock engine with a tune that doesn't detonate...
Best,
Phil
In other words...
Charlie is God...
No, Charlie is Santa Claus.
:up:
Best,
Phil
Don't forget - I did it in 17...without any boost.
I am interested in Exige S drop-in also.
What is the gain over the stock boost? Same 30 hp? I'm already at 240whp and will probably be around 265whp by the end of the year (depends when my headers get in) on stock boost and stock injectors. The last thing I want to do is to raise the boost. How much will just the SC cost?
thanks
Hehehe, we need to fix that boost problem! How about on Sunday:D
I'd drive to Kansas for this... :eek:
Would you like directions?
....The last thing I want to do is to raise the boost...
What brings you to that conclusion?
Best,
Phil
This is excellent Phil. So glad to hear good news amidst all the BS going on in the world/market/etc.
I'd be interested in a plug-and-play kit for the Exige S. I'd like to see the full meal deal in one stop: blower, ECU w/ tune, headers... all the nuts and bolts...you get the idea. The more it becomes just a matter of my finding time to do the install the more interested I become. The less likely I have to hit a dyno for tuning then my pants start to get tight over the idea of such a complete kit.
How does the stock 2ZZ hold up to the boost? Are gaskets, studs, or any other fortification items recommended?
I'm not looking to do any bottom-end or piston work. I'd be willing to update the cams and injectors as long as the ECU solution accounted for it. Like I've always said I'm not looking to squeeze out every drop of whp... but if I can get a good chunk out of it, and have a complete and reliable kit then that's good nuff for me.
Looking forward to hearing pricing.
Thanks Phil! This is going to be very, very good.
See less See more
Wow this is great!
Any chance of figuring out a kit with Exige manifolds for the Elise?
Phil, are you still running a stock fuel pump, or did you upgrade already?
This is excellent Phil. So glad to hear good news amidst all the BS going on in the world/market/etc....
...How does the stock 2ZZ hold up to the boost? Are gaskets, studs, or any other fortification items recommended? ....
...I'm not looking to do any bottom-end or piston work...
...Thanks Phil! This is going to be very, very good.
Thanks for the kind words Smoky:up: Stock 2ZZ has excellent head bolts and gakets- no problems there. Lower end and pistons should be fine. That said, the pistons are known to be the weak link in this engine...
Effective compression ratio is still just over 19:1 and that's still within the reasonable range for a high-tec, high output engine on pump gas. Several S's and even hotair M62 kits (like the one I used to have, Dave, Jim, etc) have built a pretty solid history of running this type of compression on this engine with pump gas. We'll be doing it with cooler charge temps now, however...
Stock- Although I've got a slick litte trick that I'll post about later to give your fuel system a nice bump in output...
Wow this is great!
Thanks Eric!
I guess. If I can shoe-horn it in such a way that it fits the Exige S, it will fit the Elise with those same manifolds...
You guys are wearing my fabbing fingers to the bone here!:eek:
Best,
Phil
See less See more
But Phil, it's sunny and 80 degrees here in SF/Bay Area and it's gonna be 90 when I go to SoCal tomorrow ... ugh!! Yeah, it's November, I know. Besides, I don't think the Kansas locals will like seeing CA plates in their state ;) Oh, and we have many road courses to choose from - I can think of 6 right now (Willow Spring, Fontana, ButtonWillow, Infineon, Laguna Seca, Thunderhill), sure there are more.
