ummm....about 20hp? plus the potential to upgrade later for much cheaper. If the limit of the stock fuel pump is ~ 275hp then why not have a kit just below that limit with the stock fuel pump and another kit for above that?^What's the point? Just go with BWR/Katana or an Exige S if you want less power.
Lower discharge temperatures. That's one of the advantages of a TVS when not usng an intercooler.^What's the point? Just go with BWR/Katana or an Exige S if you want less power.
I'm a little weary too, as I am one that has had a bad experience when you are pushing the 2zz with FI....I think you're really pushing the limits of the durability and reliability of the stock engine.^What's the point? Just go with BWR/Katana or an Exige S if you want less power.
I wonder if this supercharger can be expected to appear in a IC equipped kit complete with fuel pump, injectors, et al for a stock Elise
If it ends up working on the Exige manifolds you could certainly get this together!I wonder if this supercharger can be expected to appear in a IC equipped kit complete with fuel pump, injectors, et al for a stock Elise
Hey Guys and Happy Black Friday
The stock engine certainly has its own limitations. That glass ceiling will be hit at different points due to a whole number of things...
The underlying concept for this system is that you can essentially get to the upper end of the stock engine limits without an IC which keeps the system simple, clean, and less expensive than an IC'ed system *for those cars that did not come with a SC*.
That said, I'll build a kit to mount to the S manifolds as well. However remember that the setup will all ready about max out the stock pistons w/o an IC. To add an IC and bump the boost up will push you further into that glass ceiling. So, adding an IC to the TVS system for Elise or NA Exige guys, in particular, would only really be a substantial benefit if you swapped the pistons for lower compression units and then go for a 300+ whp monster...
So, I can see an upgrade path for S/Cup owners here since they struggle with IC efficiencies so much, this would make it easier for those folks to get to the 275+whp figures...
Hope that adds some clarity...
Best,
Phil
Good point on the cost issue Rob. These 2zz mills are cheap in more ways than onePhil,
On a side note, do the lower comp pistons you used weigh less?
Rob
P.S. For you folks fearing engine life issues, do bare in mind that a NEW (not rebuilt) short block and cylinder head with valves comes it under $2000 -- which is less than the SC. Just an FYI.
Yes, I upgraded my pistons so that I can go further. My ambitions are 300whp -ish-....Thanks for the clarification Phil, I agree that the stock pistons are def. maxed out around the 275 realm before needing to upgrade pistons for more durability. If you feel the stock pistons will hold with your kit, then I am game (reason being, I have the opportunity to upgrade to forged pistons, but that is a whole different ball game....compression, boost, tune, etc.) At this point, I am most concerned about reliability on the "glass engine."
Edit: I just read Rob's above post....so your pistons ARE upgraded?
I (and I'm sure others) would go for this kit for my Exige S. I have a water to air IC so that would allow me the option of pushing the envelope even further at at later date.That said, I'll build a kit to mount to the S manifolds as well. However remember that the setup will all ready about max out the stock pistons w/o an IC. To add an IC and bump the boost up will push you further into that glass ceiling. So, adding an IC to the TVS system for Elise or NA Exige guys, in particular, would only really be a substantial benefit if you swapped the pistons for lower compression units and then go for a 300+ whp monster...
Phil
Where can you buy a new short block and head at this price? Short block alone is $1699 from MWR...Phil,
Rob
