1 - 7 of 7 Posts
Gamera The Atomic Turtle
Was driving around for a day with no gas cap. After I replaced it , I realized that I should have seen a CEL.
Vendor
Because we turned the EVAP off in the tune:up:
damn. you're good. Car is even better than when I left. Clutch is much smoother. Gotta get used to letting it out a bit quicker in 1rst though..and reverse.
Carbon Fiber
It woulda been p0456, now I'm throwing this code.
I had the gas tank out recently but, gonna try to replace the cap with the locking stant one 10521 before I dig into the tank again...
If that's not it I guess I'll be working my way in...
so if you are throwing ANY codes, you should get a CEL (stock tune)?
Carbon Fiber
Can't. Running vision function stage 2 supercharger tune.
I can clear the code but it will come back in A ride or 2.
Closer than you think
As I understand it, you likely wouldn't throw a code immediately for something like a missing gas cap. The system is always checking and measuring certain parameters, building a history to compare against. That's also why it may take some time and a few ignition cycles to eliminate certain CEL codes as well (if the ECU is not manually reset).
1 - 7 of 7 Posts
