Ignition on? Tried both connectors? One in rear boot, one under pax side dash
Do not start "throwing" parts at the problem. All that does is introduce more variables. You could have a bad new part or you could mix things up or maybe the sensors you use just aren't the correct ones. It is also not inexpensive, there are four of them.Just tried the ACTRON CP9135, it got further then the rest. It said downloading information but before it gave the results the scanner shut down and re booted. Tried multiple times with same results. Have a Tech 1 from a friend being sent to me from out of town, will try that. Also think i will throw O2's at it because thats how it is acting.
Freescan won't work on the V-8's. It is for the 4 bangers. And even with that you still have to get a cable. Watch out for some of the older software, it was created to use a serial port on a older PC. Since that is not common anymore you need a convertor to get into a USB port and the older stuff has timing issues and doesn't always work with every PC. Then there is the Windows version. If you are not running XP some of the older software has problems with the newer Windows. If you are trying to do this "on the cheap" and get the freeware stuff there is no tech support when it doesn't work. You are on your own to try to figure it out and there are a lot of ways it won't work.Here:
Free V8 OBDII Scan Tool - ECU/OBDII - The Lotus Forums
Not having used freescan, I don't know how it compares
