Hello all, just finished up the supercharger upgrade on an Exige, now I cannot get the car to crank. I have found a lot of helpful threads and I have given their suggestions a try.
- I've tested all fuses in the car include F13 and R3.
- Bump tested the starter.
Things I am 99% on:
- Imobilizer is off
- Start button works, headlights shut off when start button is pressed
- Starter works when I directly power it
- Fuel pump turns on
- I am using a battery charger with engine start, holding ~13.5 volts, so I doubt I'm lacking battery.
Things I am questioning:
- Grounds, I have the car on a lift and I have traced the grounds and they all seem fine, but I'm not 100%.
- ECU, could it be fried?
- Misc plug that isn't connected
Thanks.
Update Edit #1: Under car when someone else presses start button, there is a definite click from the starter solenoid.
Update Edit #2: Testing ground resistance shows that the engine and everything has good ground, I'm not the best at using a volt meter but I'm getting near 0 ohms when testing various spots.
Things I am 99% on:
- Imobilizer is off
Thanks.
