Hi all.
My radiator fans don't come on when the car heats up, haven't since I've had the car.
If I jumper the diagnostic port on the ECU they run.
I hooked up Espritmon and watched as the (ECU) coolant temp sensor went past 100 C, no fans. For some reason, the "code 26" buttons in Espritmon are disabled so I couldn't try activating them that way. I do have an intermittent code 26 QDMB.
My AC has a leak but if I bypass the low-pressure switch and turn the AC on, the compressor runs and the fans kick on. I also get a little puddle of AC oil near the LEFT front wheel, but that's another topic.
I'm leaning toward a problem with the ECU since the fans activate by every other expected means and the coolant sensor seems to be ok.
I do have an unknown non-stock MemCal installed by the PO, seems like I would see lots of other problems if it was corrupted/faulty tho. The only other issue is a rough idle, worse when cold but still not very smooth when warm.
Any thoughts would be greatly appreciated.
