1 - 17 of 17 Posts
I am hearing a noise coming from either the supercharger or the manifold each morning when I am slowly rolling off (5mph or so). The noise is only heard in first gear. Like a quick grind of some sort then it goes away once I speed up. It seems to be louder when the vehicle is cold and is less heard once warmed up.
Performance is not affected, etc.
I checked the oil and its not low, etc
Any ideas?
Thanks.
I had what sounded like a belt "Chirp" and finally realized I could replicate it when I turned on the A/C (additional load). Did you get the pulley/belt replacment from Sector? A smaller belt seemed to fix my problem but I would call sector.
I get some slight "chirps" at low rpms in the first minute after I start mine cold. It sounds like the belt slipping. I have the updated belt/pulley.
The noise comes on at 1100 rpm. I tryed starting in 2nd and the results are the same. I will try to get a sound byte of it and see what you all thinks.
Thanks.
Where are you located?
How soon did you get your supercharger after it's release?
What year is your car?
Is there any modifications to the kit, car, or anything different about your car from an otherwise stock car with a Katana kit?
How long have you had the kit installed?
Who installed it?
What were you wearing when you first noticed the problem?
Cheers,
Brian Eyerman
I am located in MN
I got the supercharger about 2 weeks ago from Sector 111.
Besides the supercharger, I have the RTV Brace and the shift enforcer.
Other than that, stock.
Fox Valley did the installation.
Overpriced jeans. lol
Who installed it?
Cheers,
Brian Eyerman
Try driving the car in a pair of Dickies or reasonably priced jeans and let me know if this fixes the noise. It sounds weird, but I have had this problem many times before and when I changed my pants, the sounds went away.
Cheers,
Brian
after i changed my pulley it made a noise pretty close to what you are describing and i almots took it in but it went away. it was pretty weird only low speeds in 1st
No right when i started it it was chriping and it would speed up with the r's which it should but it didnt go away. Is the upgraded pully the 3.2 10"? what does it do?
hhmm im not sure, I think a 3.4 is on it now, and ive heard of people putting a 3.1 on it but I'm not totally sure whats on it now.
Bumping this old thread. Got my katana installed and at idle and low speeds it has belt chirp especially with the ac on. My current belt is the pk2195 with 3.4 pulley. Do I need a smaller belt? How do I tell if I have the old or new idler pulley?
1 - 17 of 17 Posts
