1 - 3 of 3 Posts
Unlike the USA who adopted OBD11 in 1996, the UK did not legislate the requirement of OBD11 until 2001 so a '99 S1 will not have it.
Have a look at "MEMS 1.9".
Did find the obd conector in the both on the left side,Ther are 2 ruber plugs and under the one below the obd conector is locatet.
The car is throwing one fault kode,the kode is undentified?..
The car gets fuel from the injectors ,the problem is spark.....
No spark ath all.
The coil have power 12v.
Id did also replace the coil vith no luck.
I have mesured the viering lome on the engine,and on the ecu,everything sems fine.
iff the emobiliser would be the problem why do the engine gett fuel from the injectors?
When u turn on the egnition you cann here the fuel pump and every thing sems ok.
The problem startet when the car had to do a battery replaise.
Please help me.........
1 - 3 of 3 Posts
