1 - 4 of 4 Posts
I have the sense that I need to clean something in the incoming air path. Any suggestions as to what to try first? I gather that there is no air filter to replace, so I suspect something in the hoses
start to check if you have the bottom pan drain holes drilled for the A/C Evap.
Do you A/C much?
When you do, it's best to put blower on high and turn off A/C to dry off evaporator so mold/mildew doesn't grow on it.
Covered before here, ppl often drill small holes in air tubes and spray auto parts store stuff in/around them. Or Lysol or vinegar + water.
https://www.wikihow.com/Eliminate-Odor-from-a-Car-Air-Conditioner
1 - 4 of 4 Posts
