1 - 14 of 14 Posts
Can Someone please point me to a link to purchase Lotus Elise OEM brake pads, I've been looking all afternoon and can only find info on aftermarket pads, what are the actual straight up OEM pads to buy for an exact replacement? Feel free to delete this thread if there is another answer that I can't find elsewhere on the site. :crazyeyes
Reason is I can't imagine anyone buying them: You can find them here:
http://www.lotusgarage.com/shop/index.php?l=product_list&c=109
$285 for a set of fronts.
· Premium Member
The OEM pads really aren't very good... read a few more threads before you lay down the money. Mostly they don't have the stopping power they should. Though you may not want maximum stopping power either since it's likely to be dusyt and noisy (like mine!)
· Gamera The Atomic Turtle
Did you update your rotors, or did you put them on with the stock rotors. Can the stock rotors even be machined?
Yes, I did update my rotors. Aftermarket rotors too. I don't believe stock rotors can be machined even for a performance car like Ferrari, Lotus, Porsche, etc... Someone correct me if i am wrong.
DBAUSA | Street Series
Hope this is helpful too. Also the dealership was very helpful with me in finding great rotors and pads for a great instead of paying more money for OEM. By the way he is a good friend of mine that works at the dealership ;)
· Banned
Discussion Starter · #9 ·
I was leaning towards R4S but the current breaks are OEM and they are just fine I was just trying to keep the status quo. If I go for the r4S are you saying I need to buy specific rotors to go with the brakes? I was under the impression all I need to change out was the pads (yes I'm a newbie)
· Premium Member
I'd be surprised if the current disks aren't at or close to minimum thickness (24mm) if you've worn out a set of pads on them. As everyone has said the OEM pads (and disks) aren't as good as aftermarket ones and are very expensive.
· Addict
2007 Lotus Exige S
I don’t think you need specific rotors for specific brake pads (yes some pads will cause more wear on rotors than others so do consider that), but when replacing pads you need to inspect the rotors. Make sure they are still thick enough, not gouged, not warped and not whatever else would require rotors to be replaced. I’d also suggest inspecting the calipers while you are in there too.
Discussion Starter · #12 ·
Ok so I decided on the R4S pads, and I'm just gonna go ahead and get new rotors as well and have a fresh start...
Only thing is I only see as options really the DBA4000's/5000's and I only need 4000 since I don't track the car however I don't know if i should get Slotted and drilled or just slotted!? Or if there is a better option I haven't been able to find yet.... Learning new things is frustrating sometimes :(
I stock oem pads and rotors as well as DBA rotors(1/2 the price of oem) and aftermarket pads... CL, Porterfield, etc. We are also a Sector 111 dealer and i can get you anything you need at a great price.
Contact me for pricing and orders
Best,
Steve
1 - 14 of 14 Posts
