Figured it was time to start a 'build' thread for my car. I always intend to do while I'm in the middle of the build, but end up doing them near the end as I get caught up with the actual build.
I ended up buying my Elise by pure chance. I had no intention of buying a Lotus and wasn't even looking at them. I was actually torn between a C7 Z07 or doing an E30 swap of sorts (either LS or a boosted S54). The previous year I had built a 1M clone with an E90 drivetrain so I was leaning to the Vette, since I was burnt out from the build and didn't want to spend another winter in the garage. After factoring in consumables for track days I was a little bit meh about them.
Facebook Marketplace must have known I missed my supercharged S2000, because it suggested an Elise ad. The owner was 20 minutes down the street from me, and I was having a slow Saturday. I had ridden an Elise once previously, more than a decade ago. This car looked to be rough shape, but it had a lot of the same modifications that I would've done.
The previous owner was the second owner, took care of the car, and was down to earth. Also, despite the go-fast parts (Penske shocks, BOE REV300 Kit, BWR bushings etc), he never tracked the car. The test drive was underwhelming; the car needed an alignment and I didn't really get into it. After 2 weeks of negotiations with the owner and his wife, I managed to knock $6k off the asking price and the car was mine.
Get the car titled was nerve-wrecking as the VA DMV didn't have any appointments for 3 months and I had to mail them the title. Since the car would sit for 2 months, I wasted no time and started to order parts to get the car sorted.
The end goal was to have an OEM+ build. I want a reliable track day car that I can drive to/from the track, beat around without having to worry about it breaking down, and still be able to take to the gym or whatever.
Step One - Identify what's been modified
While I ordered the parts, I set off to address the clear coat issues first.
- BOE Rev300
- BOE swirl pot
- BOE catch can
- BOE QS exhaust
- BOE Engine Block-off plates/Cooling U pipe delete
- EP Tuning Radiator
- EP Tuning Quick Release steering wheel hub
- Momo 320MM Steering Wheel
- Inokinetic ultra disks
- Inokinetic QWKBLEED SS Lines Front and SS Lines in the back
- Inokinetic shiftr111
- Inokinetic Xtender Bracket
- Inokinetic v2 arms
- Inokinetic Eliminator V3
- Inokinetic Shifter Cable
- SSC Crossgate Cable
- BWR Harness Bar
- BWR Control Arm Bushing Kit
- BWR penske single adjustable shocks
- BWR Spec 949 Racing 6UL wheels
- Wheel Studs
- Radium Engineering Clam Kit
- GARW dash
- CL5 Brake Pads
- Morimoto HID Headlight Bulbs and Ballasts
- 4 point Takata harnesses
- A/C, Radio, Airbags, Center Console, Rear Bulk Head, and Seat Belts Delete
- The peeling clear coat had to be fixed
- Needed to refit all the AC components and get the AC functioning
- Reinstall all the cluster plastics
- Get the oil temp and pressure readings on the dash to work
- Fix leaking driver side oil cooler, perform oil cooler line recall, and address the overcooling issue
- Upgrade to Rev400. While the additional power is welcome, I wanted the aftercooler more than anything else
- Radio/Headunit of sorts
- Fix the other misc stuff that's broken
- Access Panel Replacement
- Add missing grills in the front
- Side Mirror replacement
