Status
Not open for further replies.
1 - 6 of 6 Posts
Hello,
I bought this LSD (from MikeV on SpyderChat) and never installed it. I no longer have the car and have no use for this. The plan was to install in my future MR2 or Elise, but plans changed.
This is an OEM Toyota/TRD Helical LSD from a Toyota MR2-Spyder. It will fit a C56, C60, and probably any transmission that bolts up to a 1zz-fe or 2zz-ge engine, such as the C64 transmission found on the 2011 Lotus Elise with the 2zz-ge engine. It may be retrofitted into other transmissions.
It will come with the new bearings, mounting bolts, speedometer gear, washers; everything you see in the pictures. I think I have seals too, if I find them, I'll include them.
You will need to source the ring gear and output shaft yourself. You can buy them from MikeV at SpyderChat
Also, the ring gear and output shaft from a manual transmission from an 8th gen. corolla will work.
$500 shipped to US address.
1257114
1257115
1257118
1257121
1257122
Closing this.
San
1 - 6 of 6 Posts
Status
