1 - 3 of 3 Posts
I'm fitting the v8 wheel flares, wing and at the same time upgrading the front spoiler.
I'm about to put the front end back together after painting.
Does the front oil cooler ducting from the 95 s4 fit in the v8 spoiler, or will I need different parts?
Lotus made at least 4 changes to ducting around the oil coolers over the years, as well as the coolers themselves. One major difference in coolers is the location of the intlet/outlet and the mounts, as well as the plumbing from side to side. I would recommend matching the ducting to the valance you intend to use, with the notion that you may have to fettle them a bit to match your coolers.
1 - 3 of 3 Posts
