Oil leak from bolt next to/behind oil filter (46.03 part #13 in parts/service list manual.. but in the parts manual it appears to be upside down?...) there is a bolt (relief valve??)
on my "Sandwich Plate & Thermostat Assy." which had a nylon or silicon spacer.
Neither the bolt, spacer, nor where it goes is listed in the manual.
The spacer is very thin aluminum, and the bolt was apparently tightened a bit too much which caused a slight leak from there, not knowing what I was doing I tightened it a bit more, which just made the leak worse.
I can't find a spacer like the one that was on there anywhere I've gone so far, and nothing is listed in the manual, Ferrari of Denver had no clue what I was talking about, but tried to help me find a spacer, unfortunately, nothing was the correct fit.
I can take pictures if that might aid the situation.
1. Why isn't this in the Parts book?
2. Where do I find a new spacer for this?
