You're so right. Further review is required.You can never tell where a leak is coming from based on where it hits the floor.
With the drip appearing that far left of vehicle centerline it almost has to be something associated with the cam towers, covers, etc. Maybe another much less likely possibilty would be a turbo oil feed line, if the I4 has those. In any case the drip could be hitting and running along the exhaust manifold, obscuring the origination point...... The card board piece is centered on the rear engine seal. So leak is 18 inches left of that. View attachment 1315049
Will do and thanks. Keep you posted.Most common leak I've seen is from the base of the cam carriers...especially on the exhaust side.
The exhaust cam carrier holds a cupful of oil even after shutdown. Eventually it leaks.
But of course, the usual advice is to clean up any accumulated grunge, then monitor the area so that you can see where the oil is coming from.
If you are properly MOVINGDoes the exhaust manifold smoke when getting hot at start-up?
When the rear camshaft cover O rings leak, and they all do eventually, there is no doubt as its almost immediate upon starting, plus it stinks, a quick look in the mirror sends the heart rate to the stratosphere and you suddenly wish you had bought that nice little fire extinguisher on Amazon!If you are properly MOVINGmost likely you wouldn't see any smoke. Along the same lines, frequent drives minimize any smoke.
Good point, I fixed those on my Esprit years ago. Make that, decades ago. (JAE O Rings, and it is a relatively simple repair).the rear camshaft cover O rings leak,
Indeed!When the rear camshaft cover O rings leak, and they all do eventually, there is no doubt as its almost immediate upon starting, plus it stinks, a quick look in the mirror sends the heart rate to the stratosphere and you suddenly wish you had bought that nice little fire extinguisher on Amazon!![]()
Nothing unusual with anything. No smoke.Does the exhaust manifold smoke when getting hot at start-up?
