1 - 1 of 1 Posts
This is a 1zz oil pan which can be used on either 1zz or 2zz, and as most people know it has better baffling than the stock 2zz pan. its all setup already for an oil turbo line with a -10 fitting on it. You can also see on the inside where the tubing is routed below the baffle. It also has a quick dump thing which means no tools needed for doing your oil change, just unscrew the cap by hand, and screw in the hose with fitting which im sending with it also, it saves a lot of time on oil changes.
the price is $150 shipped anywhere in the lower 48 states, low ball PM's will be ignored. its boxed up and ready to go for whoever sends me the money first.
1 - 1 of 1 Posts
